How's your 350Z coping with the cold?
From what I've read the 350Z has had a bit of a "hang-up" while going into 2nd gear when is cold,
by "hang-up" I mean that it tends to not want to engage easily. This will go away as the car gets warmed-up. However, this morning being a LOT colder than usual here in Florida, my car actually grinded while going into 2nd gear. But as soon as the car got warmmed up it shifted as usual. Is this a sign that the clutch is taking it's last toll? Or have anyone else experience the same issue? Inputs welcome! |
No worries. Its just cold man. Mine does it too. My car loves the cold!
Cold air = HP! :thumbup: |
its the weight/ age of the tranny fluid. its been close to 0 or below several times, with the correct fluid for these conditions no problems
^ +1. Mine was doing it b/c I had the wrong gear oil in there. GL5 instead of GL4. I had Royal Purple and I switched to Motul. Much better.
Originally Posted by Boostedtrack350
(Post 8033004)
Originally Posted by qqqqball
(Post 8033009)
stop being a ***** i daily drive my z on long island in the ice in snow
Cold in Florida is what 70 degrees?;)
Originally Posted by R350Zz33
(Post 8033076)
Originally Posted by davidv
(Post 8033272)
Originally Posted by engiNERD350Z
(Post 8033290)
did you even read his post?
lol you're "cold" florida weather is nothing. high of 23 in WV today :(
(Post 8033290)
Originally Posted by SnyzzleZ
(Post 8033507)
Mine does the same thing, I try to let it warm up for at least 10-15 minutes before driving it and even then I shift slow until it's properly heated up.
Originally Posted by AdvanZ33
(Post 8033632)
I really needed to hear that, for a minute this morning I was thinking the worse. :o |
sucks in the snow that we just had dumped on us last night (Western PA) other than that its not bad..windows get stuck when its icy and transmission is stiff for a bit till its warm.
I cracked my bumper doing donuts...****ing drain that was covered i didn't see it =( |
Originally Posted by LuciaPwNs
(Post 8033854)
(Post 8033511)
his title and post are kinda 2 different questions.
I don't critique someone's car before I look at it just because the title says "My car photoshoot, tell me what you think" |
(Post 8033507)
Snow = :gotowned: |
http://www.dujane.com/gallery/main.p...serialNumber=1
Freezing temperatures (32 degrees) does strange things to anything filled with liquid. The shocks for example. Oil inside flows poorly. The shocks will rattle your teeth. But like everything else they warm to operating temperature in a few minutes. |
Hey bro just warm the car up in the morning for 15 minutes and you're good to go. I did this today and no problems at all. The car drives better too after it comes up to operating temp.
| All times are GMT -8. The time now is 09:33 AM. |
