Compression Ratio Calculations, Cosworth F'UP or mine?
Can't figure this one out. I've generated my own CR calculator and checked it against an online calculator. I've CC'ed the pa2688 pistons and have the dome as an advertised -2.83 cc (as per Cosworth documention) however when I work out the static CR I get a low 9.744:1 (with stock heads) or 9.42 with Cosworth heads. Whereas PA2688 are documented at 10.3:1. I wondered if someone could check my calcs and tell me where I'm going wrong.
What's also of interest is the Wiseco 11:1 CR pistons have an identacal deck height but a +7cc dome. My calculator works the Wiseco's to be 11.08:1 CR. Heads Cosworth Pistons Hi Comp Bore 95.55 Stroke 81.4 Total Displacement cc 583.6825163 Head Gasket Bore 96 Head Gasket Thickness 0.5 Total Gasket 3.6191232 Piston Deck 0.6 Total Deck 4.30232813 Piston PA2688 Dome -2.83 Heads Cosworth Combustion Chamber 58.5 Volume at TDC 69.25145133 Volume at BDC 652.9339676 Compression Ratio 9.428451752 |
| All times are GMT -8. The time now is 10:09 AM. |
