JWT clutch/flywheel combe noise at low RPM
on
Hi guys,
Just installed the clutch/flywheel on my 07 350z. My car makes this chatter/slipping noise when at low RPM (800 to 1500) especially noticeable 2nd and 3rd gear. Lets say I'm on 2nd at about 3k RPM then I let the gas go and let the car slow down to just about 1k RPM then apply gas again, it would make that noise until it gets above 2k then the noise goes away. Is that normal? I know people have experienced chatter when idle for these clutch/flywheel combo but never heard of chatter at low RPM.
Thanks for the help guys.
Yeah its that way it works without a dampener on the flywheel (dual mass wheels). Sounds a little like a loose/rattling fitting. Note, this can be assisted with the use of heavier oils in the tranny. HOWEVER BE WARNED, heavier oils are not suggested. I use them and have not had any problems yet... but before you consider them know some oils can damage certain metals in the tranny and also create a rough cold shifting situation (also not good on the tranny). With that said, the heavier oil in there make the tranny noises very livable (still there, just not bad).
Please post links to what you read.
It's natural, I have the JWT Clutch and fywheel also. You get use to it, I only really hear it when idle. It barely even notice it now. I do no regret having it at all though. (and yes that's normal).
I had the JWT clutch and flywheel on my 2008 350Z and I had all that chatter and noise your talkng about. It's normal to me I thought I could handle having a lightweight flywheel but I couldn't so I went ahead and put the stock fly back on and combined it with clutchmasters FX300 clutch. I'm happy now with no noise at all...
on
Ok guys, thanks for the response. also, when the chatter noise happens, it "feels" like the clutch is slipping a bit... like it's not accelerating has it should. also i can feel a bit of rattle from the car. does anyone have this also?
also interestingly, i don't hear any chatter at all when in neutral like many others have experienced.
Thanks
Thanks
Yes that is very normal. This is an older vid I made for someone asking the same question,
http://www.youtube.com/watch?v=YyFgTg57j0Y
Former Sponsor
on
Thanks
Thanks
a clutch is not going to slip at low load, low rpm, and then magically grip at high rpm, high load
the rattle is exactly what everyone describes - it is a byproduct of fitting a single mass flywheel such as you have
on
it's 100% in your imagination, or in how you're driving it
on
Thinks for the heads up, I just ordered my today. I've heard of the chatter, but never heard it. Oh well, I'm sure it wont be louder than my Vortech anyway.
