Swap Help
Is It Possible To Swap A 370 Motor To A 03 350z . If So How Can I Go About Doing This.
After all the search I have done, not worth it. Better off building the block.
You will need the 07 to 08 hood, and a lot of electrical work.
(Post 10247482)
If you are asking these questions, do you really think you are capable of this? Just build a DE
ive seen thread after thread about you asking questions about engine swaps OP, here are your choices:
regular VQ35DE, cheapest option, drops right in with no work LSX engine drop, not cheap but worth it, drops right in, but needs mod work and a new tranny and driveshaft Built VQ35DE, drops right in, cheaper than lsx swap, needs mod work on the engine, but nothing else Any other engine would cost way too much to benefit from so a 370 engine is out and a HR engine is out. Good luck OP. |
Originally Posted by stuartc323
(Post 10247614)
