MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine & Drivetrain (https://my350z.com/forum/engine-and-drivetrain-50/)
-   -   clutch pedal doesn't fully return (https://my350z.com/forum/engine-and-drivetrain/601060-clutch-pedal-doesnt-fully-return.html)
Blathouwers Jan 24, 2015 11:56 AM
I am having issues with getting my clutch pedal to come back after changing out my clutch and flywheel out to a stage one and lightweight flywheel. Before i did the clutch kit I had replaced the master and slave cylinder for the clutch pedal and still have the same issue. I have bled it multiple times and so did my mechanic. Any suggestions to what may be causing this issue?
superlim9 Jan 24, 2015 03:49 PM
in my experience... Pedal height needs to be adjusted... if the rod was not installed and adjusted to the right length the tension on the spring isn't enough to return the pedal to full height...
