Shawns'Z |
04-15-2015 04:45 PM |
Lean code and smoke?
I am throwing a lean code on my bank 2, sensor 1, 02 sensor. I know I need a tune due to my spacer, tp's and k&n air filter but recently my car started puffing out blueish-white smoke if I blip the throttle sitting still, but it does not smoke at all if I go WOT. the lean code also came up recently so I'm wondering if the lean condition is causing the smoke or if something else is causing both. No vacuum leaks that I can find, and did a compression check last fall(just because), all was good there. Where do I look next?
