Transmission swap
Old Apr 22, 2015 | 07:15 AM
Alech9's Avatar
Alech9
Exclamation Transmission swap
I have a 2008 350z touring coupe. It has an automatic trans in it right now but I want to put a 6spd manual in it. I've heard of guys doing it in the past so I'm wondering if it is possible. My only concern is the wiring and sensors may be different. Can anyone give me some good educated info?
Also if anyone has a copy of the wiring diagram for my car vs the manual I'd like to compare the 2.
Old Apr 22, 2015 | 07:30 AM
travlee's Avatar
travlee
Master
here are all the threads on it
https://www.google.com/?gws_rd=ssl#q...ite:my350z.com
Old Apr 22, 2015 | 07:33 AM
turboed350z's Avatar
turboed350z
Sell it and buy a manual.
Old Apr 22, 2015 | 07:37 AM
travlee's Avatar
travlee
Master
it is possible, depends on how much cussing and time you want to spend on it.....
Old Apr 22, 2015 | 08:23 AM
Alech9's Avatar
Alech9
would there be any issues with the wiring and ecu? price wise the cost is about the same as rebuilding a auto trans at a shop. I'll be doing the work myself so shop cost will not be included.
I don't want to sell the car because I've got wheels, tint, and wipper delete on the car already i dont want to deal with all that on another car.
Old Apr 22, 2015 | 08:36 AM
travlee's Avatar
travlee
Master
if i remember correctly there are some different plugs, or something.... i am not the most knowledgeable on this
Old Apr 22, 2015 | 08:59 AM
jdm-v35's Avatar
jdm-v35
I did mine(2003 g35) but I am familiar with the ins and outs of the car short of tearing down the block. If you know the car well and have a good idea about the wiring its not bad as there is really no wiring except reverse lights and neutral position sensor. Just look for the 5at to 6mt diy swap thread and it will tell you everything you need to know. once sourcing all the parts its pretty easy. I did everything except the actual clutch install and trans swap without even jacking up the car(i live in an apartment complex) and had a friend with a lift do the trans and clutch install. If I had a lift, realistically I could have completed the whole swap in 12 hrs.
If you think wheels, tint and a wiper delete is work, I would reconsider doing this swap...
Old Apr 22, 2015 | 09:06 AM
travlee's Avatar
travlee
Master
https://my350z.com/forum/engine-driv...-thread-2.html
it was in the google search i listed the first time...... just sayin
Old Apr 22, 2015 | 09:24 AM
terrasmak's Avatar
Wheels are easily moved to a different car, tint is $150 and wiper delete is $20 unless you welded the hole and painted the hatch.
I would buy a different car unless doing a non OEM engine swap or building as a dedicated race car.
Old Apr 22, 2015 | 09:34 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Terrasmak is correct; while this swap is possible, it's not easy or quick. It's quicker to just fix your car and sell it, then buy a manual tranny Z.
Old Apr 22, 2015 | 09:45 AM
mvp2765's Avatar
mvp2765
^ agreed, sell your car and get a M/T
Old Apr 22, 2015 | 10:37 AM
Alech9's Avatar
Alech9
finding a dealership or seller that would let me change my rims and wiper delete over seems like it would be hard. I have access to a car lift and i have a ton of tool. I just want to know its possible, and ill give it a shot.
Old Apr 22, 2015 | 11:04 AM
turboed350z
Because spending 2k for a tran swap is alot easier and cheaper than a 200 set of wheels and a 10 buck wiper delete....
Old Apr 22, 2015 | 02:11 PM
Alech9's Avatar
Alech9
try $1400 for the wheels. im not just going to trade them in. I'd have to swap them over
Old Apr 22, 2015 | 02:15 PM
turboed350z
Do you know how to buy a use cheap set of crap wheels to throw on the z so you can keep your 1.4k? I dont think you do. If youre not capable of doing wheel swap, i highly doubt you can do a tran swap 😂
Let me spell it out for you. Go on craigslist, search 5x114. Buy a cheap set. Put THAT set on your z. Keep your "good" wheel and sell the z.
Get a new z, then put your "good" wheels on the NEW z and sell the wheels the z cane with. Ban problem solve. Less hassle and skills required...
Old Apr 22, 2015 | 03:08 PM
terrasmak's Avatar
So you spent $1400 on rimz, take them off and install your stock wheels. Then you have nothing to worry about
Old Apr 23, 2015 | 06:20 AM
mvp2765's Avatar
mvp2765
the reason everyone has been saying to sell your car, is because this topic has been talked about 1million times.
Old Apr 23, 2015 | 06:43 AM
turboed350z
Only time a tran swap is needed is from cd01 to cd09. Otherwise, its all a waste.
Old Apr 23, 2015 | 07:03 AM
jdm-v35's Avatar
jdm-v35
It's not a waste if you can source good quality parts for a good price and have the knowledge and capability to do it all yourself. But if you're going to do it you need to be able to afford to do it right the first time.
But if the OP is worried about all the "hard work" to do a wiper delete and a $1400 set of rotas, this swap definitely is not in their best interest.
Old Apr 23, 2015 | 08:10 AM
turboed350z
The wiring, the possibility of getting a bad tran, blah blah blah. Factors. Personally i can sell the car and get a manual without losing a dime. To me, thats less than the trouble of swapping the tran. Even if you can fine the tran for a good price, youre still paying for it vs just selling the car and buying a new one breaking even in the process.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
