MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine & Drivetrain (https://my350z.com/forum/engine-and-drivetrain-50/)
-   -   Clutch doesn't stall when in gear (https://my350z.com/forum/engine-and-drivetrain/616857-clutch-doesnt-stall-when-in-gear.html)
Mullen009 Aug 5, 2017 10:49 PM
I tried posting this, so sorry for a dup thread
So a quick rundown, I've posted a forum here about the issue I was having and was trying to figure what exactly was wrong before taking it anywhere.
Car would be jittery off a stop, and if I was rolling had no problems shifting.
Tonight, I was coming from work. And came up on 2 other Zs. And against my better judgment I hit a second gear rolling jump with one of them. Got up in the rpm and tried to go to third and nothing, a brick wall. Clutch lost all pressure and wouldn't go into gear.
I had to come to a stop and press it a bunch and pressure slowly returned.
Got it into 4th and could get it rolling to turn left to try and go home. It went into first and started rolling after the light turned and when I went from first to second it had no movement. Engine revs but car won't move.
Decided to pull it over, and eventually found that if I just leave it in gear the car won't stall.
I can move the shifter between gears without pressing the clutch when it's stopped and running.
Luckily some dude came by asking for 5$ and I paid him to push me in his car back to my neighborhood.
once I got back I let it sit and cool down, and went back out and it still won't move when put into gear. There was no mechanical clinking or grinding during this push home in neutral.
When I go from gear to gear I can hear it moving in the tranny. Sounds normal, I have an assumption the clutch is shot. But I'd like to hear from others here.
I was planning to replace the slave, master, clutch, flywheel, pressure plate and throw out bearing to just do a lot at once since I might need to drop the tranny anyway. Might as well take advantage of the whole thing.
Mullen009 Aug 5, 2017 11:07 PM
Something to add, the clutch pedal was losing pressure and I'd have to pump it to bring that back.
However after this whole ordeal, the clutch pedal has all the pressure.
dcains Aug 6, 2017 12:38 AM
And now, you don't have a choice. If you have an HR car, don't use the OEM clutch slave cylunder - check out the options from ZSpeed.
Mullen009 Aug 6, 2017 11:09 AM
It is an hr, Is there one you'd recommend?
Or parts in general/ brands you've used or heard are good?
I don't want anything too extreme since I won't be using the car on a track but don't want something off eBay either.
guitman32 Aug 6, 2017 11:26 AM
Is it an HR or do you have an external CSC?
You should be able to tell if the clutch is engaging and disengaging by the transmission chatter, which would go away when you clutch in. Dumping the clutch in neutral while idling is the best way to do this. If you do hear the chatter come and go as you dump the pedal you know the the hydraulics and clutch are doing their thing (although may still be toast), and you likely broke the transmission internally. If the input shaft is spinning, a working transmission will not allow you to row through the gears like that.
A friend lost his trans that way at the track, car would shift all gears while running without clutch. Hydraulics, flywheel and clutch were fine.
MicVelo Aug 6, 2017 11:54 AM
dcains already gave you the recommendation but here:
This is the tried and true CSC replacement (been around a long time):
http://www.zspeedperformance.com/ZSp...SC-zsp2006.htm
Newer approach with good reviews as well. This one ELIMINATES the CSC and converts to external slave:
http://www.zspeedperformance.com/ZSp...e-ZSP-CMAK.htm
dcains Aug 6, 2017 12:03 PM
Mic has you covered, but I'd suggest calling ZSpeed and discussing your needs and budget to get the the correct parts.
Mullen009 Aug 6, 2017 01:07 PM
It's an hr, 08. I went and checked and when i start the car and it's idling. I don't hear the chatter anymore when the pedal is disengaged.
I can't freely run through the gears but I'd say it's somewhat similar to when the car is shut off. There is resistance this morning and if I press the pedal then the Shifter moves normallly. But without pressing the pedal the low gears don't go in and the top gears will if I press through. But I haven't done that over and over.
Yet when I pull it into any gear and let the clutch out it doesn't stall or move.
But I can hear the mechanical sounds when pressing the shifter through 1-6.
guitman32 Aug 6, 2017 05:43 PM
Starting to sound more like failing hydraulics caused you to fry the clutch. Difficult to diagnose over the computer.
Either way you have to pop the housing, the idea being you want to make sure the transmission is still good before you do.
Mullen009 Aug 6, 2017 06:51 PM
I appreciate the assistance.
I assumed it was the master or slave originally, the first issue was during a hot day I started not being able to immediately shift between gears. This eventually turned to a high rev in first to a pedal to the floor and brick wall trying to get into gear.
I changed the clutch fluid twice and it was black so I hoped it was just needing new fluid.
But then a week after the second change the car was feeling betterish, but then this happen.
What's "pop the housing"? I'm not very experienced with cars. But again I appreciate the help.
travlee Aug 7, 2017 03:30 AM
you have to drop the trans to change out the csc, if it were me i would go ahead and change the clutch while in there so you dont have to drop it again
word of advice, do not replace the slave with oem... i did this and it went out again in less than a year
Mullen009 Aug 7, 2017 04:03 AM
yea. I've seen online that you have to take the transmission out to change the CSC. I'm planning so far to do the CSC, master, clutch, flywheel, pressure plate, throw out bearing and bushings. Might do some others after talking to zspeed today.
I'm looking to do the CSC that someone posted above. This will be the first aftermarket work I've done since paying the car off in December. It still has stock air boxes.
I'm gonna call a shop today and ask about pricing. I'm not sure if I should bring it to a shop or try and find someone local that could do it for me. I don't have the tools or knowledge to do it myself, unfortunately.
travlee Aug 7, 2017 04:05 AM
first time i had a shop do it, it was $900.
