Reliable road racing DE
Old 07-07-2018, 04:18 PM
Thefbomb13
Thefbomb13's Avatar
Default Reliable road racing DE
Want to build a reliable DE motor for my club racing z that I can beat on, and looking for opinions!
I know I can get a rev up or hr but it would probably be around the same price for the conversion, but I have multiple DEs lying around.
Was looking at Z1 motorsports kit, seems it may be a little cheaper all bundled up.
https://www.z1motorsports.com/engine...el-p-4265.html
Thanks!
Old 07-07-2018, 06:20 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
a DE to Rev-Up/HR swap wouldnt be worth it unless you have some serious funds...
Just get a do a DE and modify as most you can within the letter of the law of your spec class
Old 07-08-2018, 05:24 AM
dnash
dnash's Avatar
Looks like a good start. I would look into options for upgrading the oil pump. Depending on power/rpm goals, the revup pump would probably work well.
Old 07-08-2018, 03:52 PM
Thefbomb13
Thefbomb13's Avatar
Yeah exactly what I was thinking
Compared to Nismo?
also, not sure what I should do with the valve train!
Old 07-08-2018, 07:02 PM
JTeeAre
JTeeAre's Avatar
Compared to Nismo?
Well the revup pump was designed to support the redline increase in the revup engines over the regular DE redline. HOWEVER since you want it as a race car I think there will be a good chance you will raise the redline as you upgrade the engine. According to Z1 the Nismo oil pump is good for 8500 rpm. With that info I think you're the only one that can make the choice as to which will suit you best as only you know if you will raise the redline in the future or not.
Old 07-08-2018, 09:30 PM
bealljk
bealljk's Avatar
Compared to Nismo?
consider this variant -
http://www.suckerpunchmotorsports.co...-vq35de-03-06/
Old 07-09-2018, 06:13 PM
guitman32
guitman32's Avatar
Stock DE motor + Cooling Mods =
Old 07-23-2018, 08:48 AM
Desert Z
Desert Z's Avatar
I am in the same boat. I am just going to keep my rev up motor and just get an oil cooler and focus on suspension/brakes.
Old 07-23-2018, 09:28 AM
iideadeyeii
iideadeyeii's Avatar
If you're not going FI just use a stock motor?
Old 07-24-2018, 07:22 AM
Cracka350
Cracka350's Avatar
BTW if you haven't already look into suspension options if you're looking to race. Suspension is king.
Old 07-26-2018, 04:18 PM
rcdash
rcdash's Avatar
You can put a rev up oil pump on a DE. The variable exhaust valve timing on the revup adds very little power. It's not worth the change to the different pistons that allow for more blowby in the revups. Get an oil cooler on there and monitor temps. Sway bars, racing pads, tires and good to go!
Old 08-31-2018, 10:19 AM
Cracka350
Cracka350's Avatar
I've found this vid to be extremely useful.
Old 08-31-2018, 12:38 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
Also would suggest a set of powdercoated HR headers. They are a bolt-up piece and better at scavaging exhaust.
jdm mike
South East
04-26-2011 10:59 AM
andre12031948
12-04-2010 08:05 PM
ZULATOR
07-26-2003 06:17 PM
Quick Reply: Reliable road racing DE
