mystery machine strikes again help lol
Old 02-16-2018, 03:41 PM
lawrence2012
lawrence2012's Avatar
Default mystery machine strikes again help lol
Soooo after about 6 months of fighting myself I finally got my 03 touring running! Only to have a whole lotta problems. First got it running seemed to run fine (when I say this I mean idle haven't got the tags updated so it doesn't leave the drive) was throwing a knock sensor code and a cam sensor code. Replace the knock sensor harness and the cam sensor along with valve cover gaskets fixed a wire going to the injector plug and intake gaskets. Put it all back together and the codes went away but that was short lived as I got a p0300. First thing I did was start pulling coil pack plugs found that 1&2 made no difference. Swapped the coil and the plug from the other side and still no change I did a compression check right before the car got running but I had cranked the car a lot and it came back good don't remember the numbers off hand but can get them. The tank has been cleaned with almost a 1/2 of a tank of fresh gas. Plugs are new. Back story got the car from a guy the motor wasn't in the car kid said it ran so I took his word no clue how long its been sitting or anything like that was supposed to have low miles and everything under the covers was spotless. Anyone have any suggestions as what to check? Will be working on it this weekend will update.
Old 02-17-2018, 05:42 PM
lawrence2012
So I pulled the injectors and all are spraying fuel, new plugs, the others was very black tried a different maf sensor and a throttle body still no luck
Old 02-18-2018, 09:41 AM
lawrence2012
turns out the connectors for the coils was swapped runs a little better but now I get a p0301 smh
Old 02-18-2018, 10:09 AM
Atreyu'z 350
Atreyu'z 350's Avatar
Swap a working coil to cylinder 1 and see if a misfire code follows that coil...
btw - don't trust people, cause most are shady.
Old 02-18-2018, 04:29 PM
lawrence2012
it doesn't I cant get the misfire to move off cylinder one no matter what I do lol
Old 02-19-2018, 04:54 AM
Atreyu'z 350
What's the compression # on cylinder 1? You said you had it, right?
Old 02-19-2018, 11:47 AM
lawrence2012
185 on one and 180 on 3
Skidfive805
Southern California
16
09-08-2007 07:05 AM
bbs350z
06-18-2007 05:29 PM
Quick Reply: mystery machine strikes again help lol
