Help !!! I need your measurents ...
Hello People ,
I am gearing up to use a cd 009 on the back of a xjr Jaguar 4.0 and need some info on flywheel dimensions and specs. Unfortunately I don`t have access to the 350z flywheel to hatch this plan . 1) what is the overall measurement (ring gear ) ? 2) what is the bolt circle measurement and diameter of flywheel bolts ? 3) what is the center hole diameter ? 4) Are the Nissan engines internally or externally balanced ?( I noticed in the pictures the flywheel looks to indexed by a dowel , that usually means its an external balanced engine ) There appear to be two different flywheel styles late and early , What is the difference in the two ? Thanks for any and all help |
Unfortunately, most of us don't have access to a CD09 flywheel to provide measurements.
