Coolant Reservoir Overflow
My coolant reservoir tank rises substantially after driving hard or driving for a while. I filled the coolant between min and max one morning to make sure i was not hallucinating. After driving, it was about 2-3 inches above max which is about a 5+ inch rise starting from between the min and max lines. The car is not overheating. What is the issue and how can i fix this? |
Sounds about right to me. Mine does the same thing, if not more.
Originally Posted by Uncle 'B'
(Post 10982586)
Did you find out the issue? Im having the excavt same issue as you right now with my overflow tank coolant level rising wayy above the max when i know i had left it in between the min and max. Goes up more the harder i drive it too
