Drilling engine required for pathfinder mod
EDIT: Turns out I was wrong and this is connected to the rest of the coolant system (confirmed by blowing air through other coolant ports and it affecting the level of water poured into this area). See later posts in this thread for more info if you're curious
So I've seen plenty of install guides for the pathfinder cooling mod and was planning to do it on my DE while I've got the engine out. But when I came to replace the blanking plate on the block with the new piece that allows a hose to link to the new thermostat, I looked inside and saw it's a complete dead end in there. See pic below https://cimg6.ibsrv.net/gimg/my350z....ec15f5790d.jpg So there's no way coolant is ever flowing out of there like it's meant to according to the pathfinder cooling diagrams. None of the install guides for this mod mention drilling anything in there... So i can't help but wonder if most people who've installed this have actually achieved nothing and coolant isn't flowing how they think. I did find a thread on another forum for a car where this engine is used but in front wheel drive and they said they drilled this part I'm looking at and hit an oil line of some sort. So yeah anyone who's done this mod got any thoughts on this? |
I am interested as well. I haven't taken my plate off yet but I will report back if mine is the same.
I've checked on both a DE and REVUP now and both are definitely completely sealed off dead ends. Even poured water into there to see if it escaped through some tiny hole I couldn't see. But no, it just sat there until I soaked it up with a cloth.
So yeah unless people are drilling something in there and just forgetting to mention it... It's doing nothing |
Made a video to explain in more detail:
nice video. very good info and maybe the whole pathfinder coolant mod is just BS after all? since it really goes nowhere haha
Originally Posted by jdm-v35
(Post 10983375)
I'm sure there are some people on here who've done it and actually drilled the block but going by all the DIY guides and other posts I've seen about it, I'm pretty sure most people haven't. |
I've been doing more searching as I'm baffled by so many people doing this and not noticing what I did in a few seconds, especially with some shops claiming they did the mod and then got lower coolant temps on the dyno. So I still can't help think I'm missing something.
I found an old forum post where someone said: "When you check the openings to the block at the bottom of that cover, you will see they are only small." So maybe some of these blocks do have holes down there?? But then it seems very odd that my DE imported from Japan and the UK REVUP engine that I checked definitely didn't have any holes. I also found someone on a Nissan maxima forum who mentioned the same problem I'm talking about and ended up drilling his own holes down there, but never updated the thread to say if it worked or if he had any issues after that. In that thread someone posted a picture of a VQ30DEK engine that had some holes down there, although its kind of hard to see. https://cimg8.ibsrv.net/gimg/my350z....22fcbd67ab.jpg But again, if the Japanese DE and UK REVUP engines that I checked both didn't have these holes, it seems likely that a lot of people who've done this mod don't have these holes so it isn't doing anything. Maybe all the engines in US cars do have the holes? Would be surprising as I didn't think there were any differences in the actual engine block between US and UK/JDM engines. |
There was a thread back in 2010 that discussed this very issue...same outcome though no one was able to come to a definitive conclusion as to whether that port has holes or not.
Great info though keep it going. |
Originally Posted by guitman32
(Post 10983396)
Great info though keep it going. I have a definitive conclusion for my UK and JDM engines, as like I said I've tested it by pouring water in them and it just sits there. So all that really needs confirming is do the engines for the US market have the holes or not (if they're even any different to the engines in europe and japan). The sheer amount of people in the US that have done this mod over a period of 12 years, including shops that know this engine inside out (and did dyno tests after doing the mod), makes me think the US engines must have the holes. But in reality it seems odd that Nissan would do it only for the US engines especially when it was capped off above anyway by that blanking plate. |
Hard to say exactly what the difference between your block and mine - but mine is connected and drains when filled with water. Water spills out through the sleeves. I've got 4 other engines in the garage I can test as well - I would do this test with your heads off before you completely debunk it - you may have fluid in the system where the fluid in the pathfinder cooling mod cavity cannot go anywhere. let me upload my video |
Originally Posted by bealljk
(Post 10983400)
Hard to say exactly what the difference between your block and mine - but mine is connected and drains when filled with water. Water spills out through the sleeves. I've got 4 other engines in the garage I can test as well - I would do this test with your heads off before you completely debunk it - you may have fluid in the system where the fluid in the pathfinder cooling mod cavity cannot go anywhere. let me upload my video Definitely no fluid or anything blocking mine, as the engine was completely drained as it has just been rebuilt. Also you can see from the first photo I showed, it is just completely sealed off down there. I only poured water in to make sure there wasn't just some tiny hole I couldn't see right in the corner. Although I'm curious to see your video/pictures as you said its hard to say what the difference is between yours and mine so that implies you can't actually see any holes? |
I cant see definite holes but water flows ...
dammit!! I totally filmed it portrait! my bad!! |
Thanks a lot for the video, at least that proves this mod is working for some people. I didn't try pouring that much into mine, but I poured enough to fill that area you poured it into and it didn't go anywhere until I soaked it up with a towel a few minutes later.
But you say when you look in there you can't see any holes at all? That's weird because on the VQ30DEK engine I found a pic of it looked like the holes were pretty obvious |
Sure thing Chris! I'm happy to help. I'm sorry yours isnt behaving like mine.
Might I suggest - instead of water being fed by gravity what about doing compressed air at +/- 25psi/2bar? Just a thought - |
Need to check my spare block now |
It's quite possible that different blocks were used for different model vehicles. I did a quick check for my model year (2005) and the Z block is part number 11000-CG000, while the Pathfinder block is 11000-EA200.
Originally Posted by karlt
(Post 10983444)
Is it possible the blocks you have came from another vehicle and not a Z?
(Post 10983447)
OK so after someone else here in the UK tested theirs and found water does flow through it, I tried attaching an air line to the main coolant hard line that comes out of the back of the heads and blowing a few psi of air pressure down there. To my surprise, the level of the water sat in this little area that we're talking about in this thread started to rise and fall as I turned on/off the air pressure. So it must be connected to the rest of the coolant system... which is weird because the water never drains out of there and also there's no bubbles when the level rises due to me blowing air through. So I don't really get how it's all connected especially as there's no visible holes, but it is and that's all that matters! So yeah, sorry for wasting everyone's time
