Nismo Or Jwt Cams For Hp Gains
Old 01-31-2005, 11:01 AM
topfri
topfri's Avatar
anyone know if the nismo cams are hollow like oem?
Old 01-31-2005, 11:36 AM
sentry65
the burninator
sentry65's Avatar
I can't wait to get some decent tires/suspension so I can floor it in 1st gear again.
With my combo of mods - along with the JWT cams, in 1st gear after 5000rpms, the tires lose grip and the tact jumps to redline.
I'm guessing the main culprits for losing grip on stock tires w/track rays are the tilton, 3.9 final drive, and jwt cams
I had most of my bolt on mods put on at the same time so I can't comment on the JWT's loss of low end torque because my car's low end torque is either the same or higher than stock
speedform
speedform's Avatar
What are the average install costs and install time you guys are being quoted?
Old 01-31-2005, 11:46 AM
sentry65
the burninator
sentry65's Avatar
If you're going NA for sure, I'd get the tomei cams or wait for what crawford comes up with.
JWT and nismo cams are a good compromise to get a decent boost, not lose TONS of low end torque, and still be suitable for FI.
I think I've heard average install cost is 800-1200 probably depending on the installer's experience
I don't know though. I paid 2500 to have all my stuff installed in one sitting
Old 02-02-2005, 04:39 PM
ReavTek
ReavTek's Avatar
For the tomei cams what other additional parts will I need? I have been hearing you need to do valves, springs, etc.
Old 02-02-2005, 05:02 PM
Machupo
Machupo's Avatar
sentry, you knockin' on the door of 300rwhp, yet?
i'm on my way to a pretty similar setup, might go with the tomei's though... still looking at what would go best with a bit of strokin'
Old 02-02-2005, 05:05 PM
sentry65
the burninator
sentry65's Avatar
we'll see, I think the most I can hope for with my setup on a dyno is around 280-290whp at the most
last dyno I was at 268 - kinda disappointing, but oh well. I'm going to try out another dyno just for curiosity sakes.
My A/F still needs to get tweaked. I'm getting an A/F gauge installed so I can log with a laptop and have TS more accurately tune my car - gonna be about a month I'd guess till I see what numbers I'm putting down.
Old 02-02-2005, 10:29 PM
jchen1020
jchen1020's Avatar
JWT is WAY to go. Set Idle at 850RPM, car will not stall anymore. High lift spring will help if you raise top RPM above 7000. Techno Square is good, but, you can take it in for custom ECU reflash. I use APEXI SAFCII to correct air/ fuel mixture.
Old 02-02-2005, 10:33 PM
jchen1020
jchen1020's Avatar
Again, GREAT DEAL, DO NOT MISS OUT. 500 miles only
04-22-2021 09:42 PM
11-09-2020 10:27 AM
nanotech
10-02-2015 05:02 AM
Quick Reply: Nismo Or Jwt Cams For Hp Gains
