Changing the Differential / Transmission Oil
#481
So i just finished replacing my diff fluid and I found an easier method thanks to the guy at advance auto. I went there to pick up a pump and he told me that he use to work on the Z and knows an easier way to fill the diff without using the pump. If you take the spare tire out you'll notice there is a round black rubber piece under it. If you pop it off you can run a tub through the hole down to the fill hole. All you have to do then is put one end into the fill hole and stick a funnel on the other end and then just pour the diff fluid through the trunk. There is no need to lift the car up and it fills the diff quickly without any mess. Unfortunately I didn't take any pics but it's not hard to find the rubber plug. It only takes like 10 mins to fill the diff and all you have to do is just stand there an pour.
what year is your Z ?
#482
Great DIY writeup Monsta... just changed the Differential fluid in my 04 Z auto with 67,000 miles on it (bought it used with 33,000 back in 07, flushed the tranny last year) and I'd guess it was never changed, had all the buildup on the plug and the used gear oil looked more like brown metal flake paint.... (i used the same valvoline 80w90 thats pictured above, not the synthetic)
#484
re
huh not looking forward to changing my tranny gear oil, im on the low low side tein basic damper kit. ill be jackstanding very carefully and doing it in my garage, last time i did the change i was just on eibach pro kit, this should be fun. pump suction gun is also key lol make sure gl 4 additive in the tranny and gl5 in the diff , i go to nissan for the tranny and autozone or advanced for rear gear oil ive been using lucas.
#485
#487
on
I know this thread is sorta dead, but just thought I would add my experience. I used the Motul fluid in the rear diff, and nissan transmission fluid. I didnt have any problems before, but just wanted the peace of mind that the fluid was fresh, as I just bought the car. Runs and shifts the same, so I guess no change is a good thing? I used the funnel + tubing and it worked perfect. Minimal mess with that method, Ive used the suction pumps before and would end up making a disaster, and it cost like $5 for the supplies from a hardware store, well worth it in my opinon.
#488
on
I finally did oil changes for my transmission and rear differential while I changed my motor oil.
I use red line MTL+MT-90 for tranny (couldn't find MT-85) at local store and 75W90 (GL-5) gear oil for rear differential.
I feel a little better when changing gears (1to2to3), fortunately I don't have the negative experience that some reported with red line.
I guess that it is worthy oil changes. (my car is at 83000miles)
By the way, be sure to have crush washer ready, I had to leave my car on jack stand
over night before I ran out to get correct size washer.
Your best bet is Nissan dealer, I got them from Carquest store on my way to dealer
after I bought wrong ones from Autozone and couldn't find it in O'reilly and Napa.
#489
on
Maybe I mis-read somewhere but is the OEM Manual Transmission fluid just regular non-synthetic? I thought i read somewhere that the manual transmission fluid is now synthetic....
#490
on
OK so I changed my diff fliud tonight (looked all nasty btw).
And my FSM says the diff drain/fill plugs are only 25 ft-lbs. Some others in this thread including the OP have said the diff is 55-61 ft lbs?
Maybe I'm reading the FSM wrong, but isn't that incorrect? Shouldn't it just be 25 ft-lbs?
#491
I changed my diff fluid when I got the car at 80k and it was disgusting. Probably never been done before. I just did it again today at 90k to try a new fluid and it was still very clean. I used RP the first time and the oil today (1 year later) still looked purplish. I switched to MotylGear 75w-90 to try this time.
#492
Thanks all for a great tread here.
SO to understand, I need the following:
Manual Transmission Fluid Change
Redline MTL ( GL4 ) 70W-80 - 2 quarts PLUS
Redline MT90 ( GL 4 ) 75W-90 - 2 quarts
1 Replacement Crush Washers ( part # 110264n200 )
Rear Differential Fluid Change
Redline MT90 ( GL 5 ) 75W-90 - 2 quarts
*bolts are to be torqued down to 23-28 ft/lbs
* Fluid suction Gun
Thanks
* Fluid suction Gun
Thanks
#493
Redline MT85?
Anyone try this yet..instead of mixing the MT90 with MTL?
http://www.redlineoil.com/product.aspx?pid=140&pcid=7
Recommended for Nissan 350Z and 370Z (also most Maxima, Altima & Sentra), Mitsubishi Evolution, Hyundai, and Kia applications
#494
#498
So.....
After reading all 25 pages of this thread (in regards to the manual trans)
Just use the damn OEM trans fluid. Or give Redline MT-85 75W85 GL 4 a try. And hope there are no issues.
It seems that not 1 person has had an issue with the OEM trans fluid, but at least someone has had issues with every single after market trans fluid listed in this thread.
#499
Actually just order the Redline MT85.
Brothersperformance has it for $10.99 a quart with free shipping
https://www.brothersperformance.com/...oil-75w85.aspx
Cheaper than OEM.
I will see how it holds up
Cheaper than OEM.
#500
Cheaper than OEM.
Cheaper than OEM.
This is exactly why I went with OEM. BTW..you can get the OEM for around the same cost..
http://www.thenismoshop.com/Nissan-O...00P_p_310.html
