Changing the Differential / Transmission Oil
Old 05-07-2014, 07:50 PM
  #541
chriscoupe
chriscoupe's Avatar
Thank you Monsta for the guide! Your approximate fluid amounts were good (I have a small bit left over) and directions were straight-forward. Easy and satisfying job!
Driveability didn't really change, which is a good sign. The fluids were likely decent before, but I did it anyway since I'm a new owner.
Cheers,
Chris Oster
Old 05-16-2014, 10:58 AM
  #542
Callmetony
Callmetony's Avatar
Hey guys. I paid 200$ at a Nissan dealership today to have them do a transmission flush and fill. Does this sound like a reasonable price? Of course I overpaid, but car was definitely in need. Planning to get the necessary equipment to do my own transmission flush when I move into a house with a garage next month. Just curious as to how shafted I was with the 200$ cost.
Old 05-28-2014, 03:23 PM
  #543
saputo
saputo's Avatar
Changing the tranny fluid is easier than motor oil imo. Just get the right tool to refill. Cost me 30 bucks with redline oil.
Old 08-14-2014, 06:06 PM
  #544
johndoesdamage
johndoesdamage's Avatar
anyone know AT oil pan bolt size?
Old 11-16-2014, 06:51 AM
  #545
ZBlue1
ZBlue1's Avatar
Whats up guys just recently purchased "The BlueZ" and i followed Monsta instructions and I will say it was very simply to change. So glad I did it, tranny was 1.5 quarts low.
what drained out looked like coca cola smh. shifts so much better now Wow.
Thanks to My 350Z forum and Monsta and all you guys for your inputs and info.
Walt
Monsta (02-18-2016)
Old 04-18-2015, 07:23 PM
  #546
Surfer90291
Surfer90291's Avatar
I'm about to do mine.
Little safety trick: When replacing transmission or differential fluid always remove the fill bolt first. Besides having the fluids flow out faster it's better to find out if the fill plug is stuck before draining the transmission / differential..
Monsta (02-18-2016)
Old 04-22-2015, 07:38 AM
  #547
StuLax18
General & Tech Moderator
StuLax18's Avatar
Received 3,339 Likes on 2,379 Posts
I was just about to say this after reading the OP.
Old 07-12-2015, 10:16 PM
  #548
Kpx4890
Kpx4890's Avatar
I didn't Read the whole thread but I just changed my tranny and diff fluid with valvoline sysn and used a fluid pump from advance auto so much better than using a grease gun.
Old 02-17-2016, 10:18 AM
  #549
tally350z
tally350z's Avatar
Changing the fluid in my 03 Auto, and it only drained about 4 quarts. On the service manual it says that it holds close to 10 7-8 quarts.
Dip stick says its full so why does it say it holds close to 11 quarts?
Old 02-18-2016, 02:13 AM
  #550
Monsta
Monsta's Avatar
Auto transmissions have a torque converter that holds fluid. It never drains completely by just letting the fluid flow from the drain plug.
http://auto.howstuffworks.com/auto-p...-converter.htm
Old 04-01-2016, 05:01 PM
  #551
NelDog
NelDog's Avatar
Originally Posted by Monsta
Changing Diff/Trans Fluid.
I added a pic of the transmission because it almost the same procedure.
Tools Used
10mm Allen Wrench
Drain pan
Floor jack
Four jack stands or a lift.
Suction Pump/Gun. I bought mine from Advanced Auto for $10.
Harbor Freight has one for $4.99.
Rags
Replacement oil 75W90 about 2 quarts. About 4 quarts for transmission.
Two replacement crush washers.
Update:
Adding the requirements as stated in the 2003 Service Manual
Transmission API GL-4,Viscosity SAE 75W-85
Differential API GL-5, Viscosity SAE 80W-90
Procedure
1. Make sure wheels are blocked.
2. Raise and support car making sure that it is as level as possible.
NOTE: It is better to drain the fluid when it is warm so it flows easier.
3. Use 10mm allen wrench to loosen fill plug (to ensure you can refill the differential before draining old oil).
4. Using 10mm allen wrench, loosen drain plug and allow diff to drain.
5. Wipe off excess oil from drain plug along with fine metal shavings. Remove old crush washer and install new washer.
6. After diff/trans is drained, reinstall drain plug. 23 - 28 ft-lbs for transmission; 55 - 61 ft-lbs for rear diff.
7. Use 10mm allen wrench to remove fill plug.
8. Remove old crush washer and install new washer onto the fill plug.
NOTE: To fill suction gun, I took off the top, pulled handle out of the gun and poured the oil into it. You could stick the hose into the bottle and suction it out but it wont pick up as much.
9. Using suction gun, fill diff/trans to lower level of fill plug and allow overflow of fluid to drain off.
10. Reinstall fill plug. 23 - 28 ft-lbs for transmission; 55 - 61 ft-lbs for rear diff.
11. Double-check all plugs for correct torque (DO NOT OVERTIGHTEN) and wipe off any excess oil.
12. Lower the car.
NOTE: Since you have the car raised it is a good time to change the engine oil, check your tires for feathering, check your exhaust for leaks and bottoming, check your fuel lines for damage and anything else that may look unusual under your car.
I have been looking for an updated part number for the Nissan OEM MTF. All sites/vendors I found quote this one: 999MP-MTF00P 75W-85. I went to my local Nissan Dealership today and they told me they didn't have that one, but another one with a different part number came up: 99998-75W85
Newer/Updated Manual Transmission Fluid for the 350Z? P/N: 99998-75W85
Can some confirm if this will work for my 2006 Nissan 350Z Roadster 6 speed manual transmission? I can't find anywhere on the bottle if it is GL-4 or GL-5. Thanks everyone
Old 07-18-2016, 06:06 AM
  #552
Dhawk350Z
Dhawk350Z's Avatar
Tools Used
10mm Allen Wrench
Drain pan
Floor jack
Rags
Update:
Procedure
12. Lower the car.
I'm confused and yes I'm a newbie but does the differential and trans oil/fluid go to the same place with the suction pump gun?
Old 07-18-2016, 06:52 AM
  #553
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
Straight answer: no, these are two different and separate components. One sits aft of the engine and the other towards the rear of the Z, between the two rear wheels. Two different types of lubricants are needed and you'll need to use the pump to fill both set of components.
Old 07-18-2016, 09:39 AM
  #554
Dhawk350Z
Dhawk350Z's Avatar
In the main post at what point does he change the rear wheel differential? All I'm seeing is the tranny fluid? Thanks for your help
Old 07-18-2016, 10:06 AM
  #555
dkmura
dkmura's Avatar
Reread that first post again. The OP combined the two operations, which is what most of us do when we've got the car up in the air. He talks about draining the diff first and doing the tranny next, but you can do them in whatever order you'd like. Have you worked on your Z much?
Old 07-18-2016, 10:45 AM
  #556
Dhawk350Z
Dhawk350Z's Avatar
Yes nothing major of course still learning. I've only done things such as replacing air intake, brakes, rotors, and also help with a full exhaust system. Also done a little bit of cosmetic work little things like installing front lip splitter, a new hood, and blacking out tail lights but this will be my first time dealing with anything with the transmission.
Old 08-27-2016, 09:56 AM
  #557
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
So I need 4 qts of mt-85 redline for the transmission?
Or should I go with the 75w-85 redline?
Is the the goodies???
https://www.z1motorsports.com/transm...85-p-4770.html
Gues got me all confused up in here
Old 08-27-2016, 10:43 AM
  #558
dkmura
dkmura's Avatar
Don't be confused. I usually only drain about 3.25 quarts of MT-85 from my tranny, so four quarts should do the job. Redline recommends MT-85 for our trannys, as it fits Nissan viscosity recommendations.
dboyzalter (08-27-2016)
Old 08-27-2016, 03:05 PM
  #559
dboyzalter
dboyzalter's Avatar
Thanks you the man... Gotta get my shitbox chevy squared away before I tare into the Z again, just ordered new subframe and diff bushings so I might as well swap out some tranny fluid while im at it.
Old 04-01-2019, 06:38 PM
  #560
noobie_1337
noobie_1337's Avatar
This is the correct redline product for the diff yes?
Red Line 57904 (75W90) Synthetic Gear Oil - 1 Quart Red Line 57904 (75W90) Synthetic Gear Oil - 1 Quart
Also does anyone know the washer needed? (or if it's even necessary to replace it)
Thx
Quick Reply: Changing the Differential / Transmission Oil
