Utec twin turbo base map.
Old 03-30-2018, 04:12 AM
*Dori star*
*Dori star*'s Avatar
Default Utec twin turbo base map.
Having completet my Gtm twin turbo install i need a base map for my Utec, to start the car on.
running 600cc DW Injectors it's hard to find anything compatable.
anyone Got something for a fellow Utec dude.
Old 03-30-2018, 06:25 AM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
PM iideadeyeii I think he is well-versed with the UTEC setup.
*Dori star* (03-30-2018)
Old 03-30-2018, 08:54 AM
andybp
andybp's Avatar
the hks map ran 600cc injectors
Old 03-30-2018, 10:39 AM
iideadeyeii
iideadeyeii's Avatar
https://turboxs.com/engine-managemen...continued.html
Click on attachments.
I'd use the APS 550cc map and go from there which has "aggressive" timing parameters compared to the TN kit which is 17 at full boost vs like 11-12.
I am not sure how much boost the APS is meant for, but you can see table max boost when it's loaded.
It will run, but if anything you'll run a little rich, but that's an easy fix
The following 2 users liked this post by iideadeyeii:
*Dori star* (03-30-2018), bealljk (03-30-2018)
Old 03-30-2018, 11:56 AM
*Dori star*
Thank you sir.
I didn´t know they still kept the maps on the webpage. but awesome!
That will get it running untill tuned...
Edit: i can´t see the data correct, is the files word files or what do you view them with?
Old 03-30-2018, 03:59 PM
Cux350z
hatersgonnahate
Cux350z's Avatar
add a .txt extension to the end and open with notepad.
UTEC is antiquated.
Old 03-31-2018, 09:55 AM
*Dori star*
Thx.
And might be, but still a proven performer.
Old 04-15-2018, 09:28 PM
*Dori star*
Thanks for all the help so far. Much apriciated.
but i'm still having trouble Reading the files in notepad.
when i view them, it's all Numbers in no apperent order.
I just wanna make sure i put the right Numbers in the right colums. Any thoughts?
Old 04-16-2018, 07:05 AM
iideadeyeii
Huh? Just upload it to Utec and read/modify it there
Old 04-16-2018, 11:08 AM
*Dori star*
I know.... i'm new to Utec.
i need to reed some more about it before i ask stupid questions.
i'll try and upload the files and see what it does
ishyne22
03-24-2012 04:22 AM
taywan
11-09-2011 05:49 PM
jeffie7
06-02-2011 06:04 PM
Quick Reply: Utec twin turbo base map.
