Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2JZ-GTE VVTI swap thread.
Old Oct 28, 2014 | 11:25 AM
  #361
NOLAGG's Avatar
NOLAGG
Originally Posted by midz350
I'm using the OEM pedal and welding the cable to it.
The cable is out of old an Nissan Cefiro/Altima. It's a perfect fit.
Will try to go and get some pics.
That'd be awesome and holding you to it lol. Deff need to see how you're going or did go about welding the cable and how did you come to the conclusion that's the cable to use? Had one laying around?
Sorry for all the questions I just want more or less be fully prepared before I drop in motor.thanks again midz
Old Oct 28, 2014 | 12:28 PM
  #362
midz350's Avatar
midz350
It's more of a drilling than welding actually. Example (not mine) Name:  IMG_0880_zps671ab887.jpg
We use the same cable for most of the 2JZ swap here.
Old Oct 28, 2014 | 05:58 PM
  #363
NOLAGG's Avatar
NOLAGG
Ok thanks man , do you know the exact cable so I can look into getting it?
Old Jan 15, 2015 | 08:55 PM
  #364
midz350's Avatar
midz350
NOLAGG: I will ask for that cable for you this week.
Back from the dead.
I can't say when it will be done. Maybe in a week, month or another year. But we are getting there.
Attached Thumbnails My 2JZ-GTE VVTI swap thread.-imag0198_burst001.jpg   My 2JZ-GTE VVTI swap thread.-imag0199.jpg   My 2JZ-GTE VVTI swap thread.-imag0195.jpg   My 2JZ-GTE VVTI swap thread.-imag0196.jpg   My 2JZ-GTE VVTI swap thread.-imag0193.jpg
Old Jan 17, 2015 | 06:42 PM
  #365
Total D's Avatar
Total D
midz what trans are you using? V160? or CD?
Motor looks good by the way. I wish I had motor to look at lol.
Jeremiah
Old Jan 17, 2015 | 06:57 PM
  #366
midz350's Avatar
midz350
Jeremiah
I'm using the CD trans with a custom adaptor, VQ clutch and 2JZ flywheel + flexplate.
Old Mar 9, 2015 | 12:03 AM
  #367
Yaustinz33's Avatar
Yaustinz33
Default 2jz swap!?
just curious but I know the de motor I have will KNOCK on my door soon so my question is what exactly would it take to drop a 2jz in a 03 350z? I know I need fuel pump harness ecu motor 5speed trans intercooler custom driveshaft shifter extension motor mounts crossmember what else would I need? what tranny can I use? different diff? hopefully will be doing this soon so if any one has experience let me know!!
Old Mar 15, 2015 | 07:30 AM
  #368
midz350's Avatar
midz350
Here is a little teaser
Attached Thumbnails My 2JZ-GTE VVTI swap thread.-img-20150315-wa0004.jpg   My 2JZ-GTE VVTI swap thread.-img-20150315-wa0005.jpg
Old Mar 15, 2015 | 08:36 AM
  #369
Classy's Avatar
Classy
Looks like you are getting close
Old Mar 15, 2015 | 05:42 PM
  #370
Conway_160's Avatar
Conway_160
Look at that little babby fmic...how cute :-) on a serious note looks good!
Old Mar 15, 2015 | 07:38 PM
  #371
midz350's Avatar
midz350
I think its a 31"x12"x4".
Old Mar 16, 2015 | 07:28 AM
  #372
Conway_160's Avatar
Conway_160
You should double check that, pictures can be deceiving but it appears to be 2" deep max.
Can't wait for the videos of this thing running and roasting tires!
Old Mar 16, 2015 | 10:28 AM
  #373
midz350's Avatar
midz350
Sorry, I meant to say Its a 3" core with 3" piping.
I'm using my old Greddy dual turbo ti-c. I can't wait to hear what will the 2jz sound through that thing
Old Mar 24, 2015 | 09:15 PM
  #374
midz350's Avatar
midz350
Last minute addition.
After starting the car this week, will install Titan 272 cams and BC springs before tuning.
This hopefully should get me to low 600whp on pump gas.
Old Mar 30, 2015 | 04:04 AM
  #375
midz350's Avatar
midz350
Just received this:
Today will start the car. If everything goes as plan, then will install the cams next week before tuning.
I can't believe 4 years of waiting is about to end soon.
BTW, I love the new engine swap sub forum.
Old Apr 6, 2015 | 10:34 AM
  #376
midz350's Avatar
midz350
Originally Posted by Jazzyfella
How did starting the car go??!!!
We got busy fixing some small things here and there. Too many small thing that wasted our time because the stupid old shop used the wrong bolts.
W‏e might‏ start it tonight.
I installed the Speedhut tach gauge. It was a PITA! I'm not sure if everyone removed the silver plastic frame inside the cluster or not!! Will redo it again tonight. I forgot to install the push button.
Also the tranny needs to be shortened more. About an inch or so. We still have room since the last shop didn't shortened it enough.
Will take pics today. we have been spending about 6-8h a day for the last 3days trying to finish it up.
Old Apr 7, 2015 | 01:07 AM
  #377
midz350's Avatar
midz350
update,
99% wired up and everything was checked engine/wiring wise and so we started cranking and it was about to start before we discover a fuel leak from the tank. Stupid old shop fwkd the screws. It was around 6am, so we called it a day. Later tonight with new screws and an O ring and we will fire that biach.
Couple of pics I took last night before I started working on the shifter. I'm 90% happy with the shifter location for now. Will try to remember to take pics for it tonight.
Rear mounted battery:
Speedhut tachometer gauge installed:
Old Apr 7, 2015 | 03:31 AM
  #378
Classy's Avatar
Classy
I am excited for you!
Old Apr 8, 2015 | 09:03 PM
  #379
midz350's Avatar
midz350
It's aliiiiiiiiiiiive
The car is running. It took a lot of tries, but finally started.
We let it idle for about 20minutes. There was a couple of vacuum and oil leaks. We will take the engine and transmission out since there was a leak from the FW bolts and need to check the FW spacer since there was a slight vibration. And also there is a noise coming from the pulleys area and will check it. (Second video)
The Haltech manager really spoiled me. The AEM tuner feels like working on Windows98.
Old Apr 9, 2015 | 03:30 AM
  #380
Classy's Avatar
Classy
Congratulations! Hammer out the little details and enjoy a 350Z with 600hp really reliably!
