Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Sikky LS swap with boost
Old 04-17-2015, 10:41 AM
RMCRZ
RMCRZ's Avatar
Arrow Sikky LS swap with boost
For some the LS swap might be enough, but at 6,000 Ft it needed to be force feed. I didn't want a screw or roots blower, and I didn't want to mess with rear mount turbos and the oiling nightmare that comes with them and since no one makes anything else I designed and built this setup. I have over 1,000 miles on this setup and it is my daily driver. It started with a Vortech V3 Si and made 650 at 7 psi boost, now I have a Paxton Novi 1500 on it and have not had a chance to strap it to the dyno yet.
Zach
SponGer (11-01-2015)
Old 04-17-2015, 11:46 AM
deliabastian
deliabastian's Avatar
Thanks for this. I'm sure a lot will benefit from your tips.
Old 04-17-2015, 07:02 PM
rustyschopshop
rustyschopshop's Avatar
Awsome set up, any dyno charts on your build by chance?
Old 04-20-2015, 10:05 AM
RMCRZ
RMCRZ's Avatar
This is the Dyno graph with Vortech V3 Si.
Old 04-20-2015, 10:11 AM
jdm-v35
jdm-v35's Avatar
wow this is an amazing setup. did you still retain A/C? Hope to be able to see this thing sometime.
Old 04-21-2015, 01:50 PM
rustyschopshop
Awsome numbers, I love the torque.
Old 04-21-2015, 03:13 PM
RMCRZ
RMCRZ's Avatar
This is the LS dyno graph and the VQ dyno graph lol, there is a little more torque with the LS. I had a Vortech V-2 Ti on the VQ with a wastegate set at 17psi.
Old 04-23-2015, 06:39 AM
mkiv20vt
mkiv20vt's Avatar
Clean install sir. Did you do the swap yourself?
Old 04-23-2015, 07:26 PM
josh.box15
josh.box15's Avatar
what all did you have do as far as fitment goes with the LS swap?
Old 04-23-2015, 08:06 PM
RMCRZ
RMCRZ's Avatar
Myself and a co-worker did the swap over about a 2 month time span. I had most of the big parts from another swap I was going to do but sold the car, so they had to go into something. The swap is not bad to do, fitment wise there was just an issue with the 1 7/8" headers. To me it seems like Sikky made the 1 3/4" headers fit great, but 1 7/8" headers are off the same design with slightly bigger tubes and they hit on the steering shaft and the starter boss of the bell housing. Both issues where easy to fix, I just marked the steering shaft and pull the header and pressed a small dent into the tube and no more issue. The bell housing is almost 1/2" thick where it was touching so I just took about 1/8" off and no more issue. Everything else fit perfect and I would use the same swap kit again.
Old 04-23-2015, 09:48 PM
zach711f
zach711f's Avatar
What Ls motor? And and what do you have done internally?
Old 04-24-2015, 05:44 PM
RMCRZ
RMCRZ's Avatar
The motor is a LS1 5.7L with stock rods and pistons, supercharger spec cam, and ported 243 heads.
Old 04-25-2015, 11:30 AM
zach711f
zach711f's Avatar
Very nice. I'm looking to go the same direct with my ls2
Old 04-27-2015, 08:23 PM
Justin100
Justin100's Avatar
d1auto (10-29-2015)
Old 04-28-2015, 01:40 AM
zach711f
zach711f's Avatar
What kit did you use? Corvette?
Old 04-28-2015, 08:35 PM
RMCRZ
RMCRZ's Avatar
Yes I used the C5/C6 Corvette accessories and balancer. I wanted to have the most room I could for the blower and airfilter to clear the fans and radiator, plus I think the corvette accessories look nicer than the GTO or F-body accessories, plus I can put a flip drive belt setup on it for a corvette and then run a dedicated 8 or 10 rib belt for the supercharger.
Old 04-29-2015, 08:09 AM
zach711f
zach711f's Avatar
Nice. I'm looking into the same setup. Just trying to find a good deal.
Old 04-29-2015, 08:10 AM
zach711f
zach711f's Avatar
Any video of this car? I wanna hear this thing running
Old 06-20-2015, 02:12 PM
zach711f
zach711f's Avatar
The bracket looks custom.mi would to buy one
Old 10-29-2015, 11:04 PM
d1auto
d1auto's Avatar
Would love to see video on this
Quick Reply: Sikky LS swap with boost
