MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine (https://my350z.com/forum/engine-365/)
-   -   S-MAX's solution for a colder air intake ..... the S-MAX Ice Tube ! (https://my350z.com/forum/engine/361273-s-maxs-solution-for-a-colder-air-intake-the-s-max-ice-tube.html)
SPEEDMAX CORP May 22, 2008 12:31 PM
http://i135.photobucket.com/albums/q...axbanner-5.jpg
Speed Max Corp would like to introduce the S-MAX Ice Tube, the best source to get the lowest intake air temp.
Here's a brief description of the S-MAX Ice Tube ........
"The Ice Tube is a breakthrough air cooling system for naturally aspirated engines that uses S-MAX Intercooler's patented internal coil system technology. Intake air travels through a 4" aluminum tube that is wrapped around internally by an aluminum coil. The coil is attached to a cooling system like our CO2 kits. When activated, the CO2 traveling through the coil creates a freezing chamber inside the Ice Tube, chilling the air just before the intake.
The Ice Tube is available with 2.5" and 3" inlets to fit most applications and measures 9.75" in length. And although it is designed for aspirated engines, it is also a great complement for those looking to supplement an intercooler in turbocharged engines."
The S-MAX Ice Tube ($249.00) with a S-MAX CO2 kit ($389.00) usually retails for $638.00 + shipping .
Forum member's price is $589.00 shipped !!!
(within the 48 states.)
(Please specify either 2.5" or 3" Ice Tube and color of bottle ; red / blue / purple)
http://i135.photobucket.com/albums/q...e/IceTube3.jpg
http://i135.photobucket.com/albums/q...e/IceTube2.jpg
http://i135.photobucket.com/albums/q...e/IceTube1.jpg
http://i135.photobucket.com/albums/q...hoang/kit2.jpg
http://i135.photobucket.com/albums/q...hoang/kit1.jpg
*** Pictures below shows a cut-out to display the internal coil of the Ice Tube
and a picture of the Ice Tube installed on a display motor.***
http://i135.photobucket.com/albums/q...ternalcoil.jpg
http://i135.photobucket.com/albums/q...g/P1020237.jpg
To locate a dealer in your area or if you have any questions, please PM me. Thanks !
- Billy
billy@speedmaxperformance.com
djtimodj May 22, 2008 01:32 PM
Dyno's ???
I dont think the air has enough time incontact with the cooler to have much effect on air temp ??
SPEEDMAX CORP May 30, 2008 11:21 AM
Originally Posted by djtimodj
Dyno's ???
Here is a graph sheet with some numbers from dyno testing performed by GTR High Performance. With multiple runs, the S-MAX Ice Tube proved to give an average of 5.24% whp gains and 4.27% in max torque gains. And they also did a test using two 5 second blast with a 2 minute interval which showed a much bigger gain. It should be self explanatory but if you do have any questions, please let me know.
http://i135.photobucket.com/albums/q...etestchart.jpg
- Billy
