Misc used Engine Bay connectors, with pigtails, lots of them
Not sure if they belong in this section, never seen these for sale. Since they came out of the engine bay I chose this section.
Price: $15 each. You may not like the price but if you try to buy these new.......good luck. Youll pay 40 a pair easy and you will be guessing at getting the correct ones. Discounts for multiple purchases I do not have the connectors detailed. Let me know which connector you need, how many pins/wires and if it is a 2 row or single row connector. I have another harness coming this week that I will be taking some connectors for my wire tuck. I also have a few broken ones i need to replace. I bought this original harness when my TB connector got smashed. http://i265.photobucket.com/albums/i...B471E92DAE.jpg http://i265.photobucket.com/albums/i...B46CD903EB.jpg http://i265.photobucket.com/albums/i...B46802F038.jpg http://i265.photobucket.com/albums/i...B4626BC041.jpg http://i265.photobucket.com/albums/i...B45CB64B37.jpg http://i265.photobucket.com/albums/i...B455DFAC09.jpg |
Did my bothering you give you the erge to sell these :o :D
Bump for a great seller!!! Chris |
Kinda reinvigorated me to do my wire tuck and harness work. I have another harness coming friday that is the other half of the engine bay and I will use it just in case I break anything. Ill part it out as well when i get the parts i need.
These are "rare" in the fact you cannot readily find them for sale individually. |
My completed injector harness
http://i265.photobucket.com/albums/i...ABE7DBCF7D.jpg Donor harness parts for sale. 6 clips. Common wire is short but the signal wires are long. Perfect for anyone who needs to repair a broken clip. http://i265.photobucket.com/albums/i...ABCFC54299.jpg |
Have a 2nd engine harness to tear apart as well.
Have most every plug you can think of in the engine bay. Oil pressure sender/ps pressure sender Injectors Coil Packs Cam pos sensors Cam pos solenoid 02 sensors, 4 pin only since not wideband TB Start single wire AC compressor single wire Coolant temp sender Injector main 8 pin Crank Pos NO Maf or alternator 2 pin |
PM'd
Re-Opened to finish the sale of unsold items.
^Thanks
Just sold a major part of the 2nd harness (transmission harness) Now have a MAF connector for sale...its a special one so priced at $20 |
Ill take the sub harness part that has cylinder 1 & 3 coil clips and the vtc clip. PM me.
Remind me Thurs before we leave to glance at that maf sensor as I may want to replace mine in the near future.
Bump |
^already sold the maf connector and will ship on the 29th.
Originally Posted by silencedeyes
(Post 10396389)
Ok thanx>
Oh OK. No biggie.
Thanks |
BUMP
MAF connector sold and shipped. No more maf, cam pos/crank or throttle body connectors left. Still have several coil pack clips, injector clips and other misc connectors. |
I need TB & the blue/green exh cam connectors on the front timing cover for rev up. Thanks
Are the cam connectors the same as the non revup intake? I have no reference otherwise.
I will check to see what I have. |
I have 1 green cam pos sol for non revup intake...dont know if it fits your exhaust. Wouldnt think so since Nissan likes to make connectors with different wing offset to prevent people from putting the wrong connector on a nearby device.
Im running out of useful connectors...about ready to scrap this harness! |
I am not sure of the pin out, but what I need is:
2- Coil pack connectors 2- Cam POS sensor connectors (left and right side) Price shipped to 32817 if you can good sir. |
You should have told me this saturday and I could have brought then to you. In orlando this week.
I definitely have coil pack connectors but no cam position sensor connectors...those are like gold and I'm all out. Do you need pigtails on the coil packs and if so what wire colors for the signal pins since there are 6 different ones. I can try to provide the same wire color so your splice is clean and the color stays correct. |
ttt
