Z1 Motorsports: Momentum Performance Products
Momentum Performance Products! Although Momentum Performance no longer exists, Z1 Motorsports has several of these items in stock & ready to ship. Z1 Motorsports M-Spec Shift Knob Kit https://cimg6.ibsrv.net/gimg/my350z....751a2ce988.jpg This knob is CAD designed and CNC machined from aircraft grade 6061 aluminum, then black hard anodized for increased durability. The shift pattern on the top is laser etched to eliminate the chance of wear over time. Precision machined threads mean no more plastic inserts to strip out or get loose over time. These knobs are the perfect finishing touch to the interior of your Z or G. M10 X1.25 fitment also fit a variety of Nissan's, Infiniti's, and other makes! Additionally, we will be including one Z1 Motorsports Machined Aluminum Shift Knob Finisher at no extra cost! Available in 3 different styles and your choice of 2 different finishes: Polished Aluminum or Black hard anodized. Order Here! Momentum Performance 350Z / G35 Cat Delete Y-Pipe https://cimg8.ibsrv.net/gimg/my350z....377849aaa3.jpg The Momentum Performance 350Z / G35 Cat Delete Y-Pipe was designed for someone wanting all out performance and the ultimate airflow. Since this Y-Pipe has integrated test pipes which removes the catalytic converters it is intended for off road use only. By deleting the factory catalytic converters and replacing them with the Momentum Performance 350Z / G35 Y-Pipe not only are the multiple welds and seams of the factory exhaust system eliminated but important weight savings over stock are also introduced. The Momentum Y-Pipe’s integrated test pipes offer a shallower angle than other products, and are manufactured out of TIG welded, mandrel bent 304 stainless steel for the ultimate in strength and corrosion protection. The 350Z / G35 Y-Pipe reduces exhaust heat, flow matches exhaust gases for more power production and improves engine breathing. This Cat Delete Y-Pipe also offers added convenience when servicing the transmission / changing the clutch by allowing you to leave the exhaust in place completely. Manual transmissions can be removed through the opening of the Y-Pipe meaning (for routine maintenance) you never need to remove the Y-Pipe once it is installed. Order Here! Momentum Performance 350Z / G35 Solid Transmission Mount https://cimg1.ibsrv.net/gimg/my350z....b58fe3ad74.jpg For the driver who wants to capture as much engine power as possible, the Momentum Performance Solid Transmission Mount takes out all of the slop and lets you put the power to the ground. If you spend a lot of time on the track and value responsive suspension tuning, you will appreciate the tactile feedback you get with a stiffer platform. The mount is machined from 6061 aluminum, with 304 stainless inserts and installs with the factory hardware. Order Here! Momentum Performance Single Turbo Kit 350Z / G35 http://b.vimeocdn.com/ts/462/291/462291983_640.jpg https://cimg4.ibsrv.net/gimg/my350z....58417efa85.jpg The Momentum Performance turbo kit is an amalgamation of the finest components in the market plus their own proprietary tubing and tune that delivers a corvette stomping 350Z / G35 to the end user. This turbo kit has been field tested with real data for over five years and 100,000 miles. You can be ensured that the power, durability, and drivability are the best they can be. Momentum's manufacturing process promises consistent and predictable installation times and efforts by ensuring each individual piece meets their strict standards. 2014 Update : Z1 Motorsports has Momentum Single Turbo Kits available, however in house installation and tuning is required. Please call us for details and to set up your appointment. |
Bump!
Momentum Performance Cold Air Intake Kit are selling fast and appointments have been arranged for the turbo kit install. Don't waste time!
-Rod- |
All items in stock.
-Rod- |
Thanks for the orders.
-Rod- |
In stock.
-Rod- |
PM for pricing.
-Rod- |
In stock!
-Z1- |
Ready to ship.
-Rod- |
bump
-Rod- |
In stock
-Rod- |
Pm for pricing.
-Z1- |
In stock!
Z1 |
bump
how much for the : Momentum Performance 350Z / G35 Y-Pipe Back Dual Exhaust..................and the Momentum Performance 350Z / G35 Cat Delete Y-Pipe.
Originally Posted by Jcruz131
(Post 10366948)
Z1 |
