Z1 Motorsports: 350Z/G35 Oil Cooler Kit Starting at $398
Z1 Motorsports 350Z/G35 Oil Cooler Kit for all '03+ 350Z (including HR engines) and all '02+ G35 models (both Sedan and Coupe) https://cimg0.ibsrv.net/gimg/my350z....30564fe1b0.jpg Designed with the highest quality products available to provide efficient cooling, trouble free usage, and simple installation. The Z1 Motorsports Oil Cooler Kit comes complete with all necessary components for installing on an NA car with a stock fascia. Forced induction cars please see the note at the bottom of the listing. The Z1 Motorsports 350Z/G35 Oil Cooler Kit features the following components standard: 1x Oil Cooler Core (19 Row Mocal Standard; Additional sizes and Manufacturer available) 1x Z1 -10 AN SS Oil Cooler Line Set (Optional protective sleeving available pre-installed) 1x Mocal Sandwich Adapter (Non-Thermostatic Standard; Optional Thermostatic model available) 1x Setrab Oil Cooler Lower Mount 1x Z1 Motorsports 350Z/G35 Oil Cooler Upper Mount 1x Z1 Motorsports 350Z/G35 Oil Cooler Install Hardware Kit 1x Z1 Motorsports 350Z/G35 Oil Cooler Installation Instructions 2x Setrab (-10 AN to 22mm Port) Adapter Fittings (Cooler) 2x Mocal (-10 AN to 22mm Port) Adapter Fittings (Sandwich adapter) 2x 13/16" Rubber Seal (Sandwich Adapter) Z1 Motorsports Oil Coolers now come standard with lower cost Mocal cores with the option to choose Setrab. MOCAL Oil Control Systems is a leader in the oil cooler market providing highly efficient cores to all facets of automotive performance. Unlike our various competitors' oil cooler packages, Z1 Motorsports has addressed the various issues with all current oil cooler kits on the market and has created an oil cooler kit the brings the best of them all to one kit. Here are a few key comparisons between the Z1 Motorsports Oil Cooler Kit and our...competitors. The Oil Lines - The Z1 Motorsports kit uses fully braided stainless steel -10 AN (5/8") line, offering both increased oil capacity and higher flow volumes. Uses OEM Style Oil Filter - You retain your OE Nissan Oil Filter. This means there will not be any confusion when you go to do your next oil change. Freedom to Choose - Unlike other kits, we let YOU choose the kit you need. You can custom build you kit depending on your driving style, needs and budget. Tech Support / Install Instructions - Each kit comes complete with the necessary, easy to use, step-by-step installation instructions (which can also be found online on our website). Protective Line Wrapping - Available pre-installed, this wrapping prevents damage to both the line and the chassis as a result of rubbing against one another. This shielding is form fitting and requires no maintanence or zip ties. Upper Core Support Bracket - Allows for proper securing of the core support, preventing fore and aft movement during hard acceleration/deacceleration or impacts. This prevents possible damage to the core support itself an the oil cooler assembly. Designed in house, the custom Z1 Motorsports oil cooler bracket supplied in this kit is infinitely variable and offers universal fitment regardless of model. This single bracket will fit all three available Setrab cores and all three chassis. The upper leg of the bracket will attach to the existing threaded rivet nut found on the G35 Coupe and Sedan. 350Z owners will need to drill and attach a new threaded rivet nut (supplied in the kit) to properly fasten the the bracket. Please contact any of our sales reps for Forum pricing or click Here to place you order. |
Keep your oil temps lower and save damage to your motor with the Z1 oil cooler.
https://cimg7.ibsrv.net/gimg/my350z....1f3473bf02.jpg |
Rod Summers uses the Setreb oil cooler for his boosted G35 track car. Protect your motor and extent the life with a Z1 oil cooler kit.
https://cimg9.ibsrv.net/gimg/my350z....cab48b7cf1.jpg |
Oil cooler kits in stock.
Extend the life of your motor with the Z1 oil cooler setup.
https://cimg2.ibsrv.net/gimg/my350z....e22a92a138.jpg |
In stock
Select the oil cooler kit options that will work best for your street or track car.
https://cimg3.ibsrv.net/gimg/my350z....f4eff081a.jpeg |
Z1 oil cooler kit for the 350z is the best and highest flowing setups on the market today.
Keep those temp under control with the Z1 oil cooler kit for the track or street.
https://cimg4.ibsrv.net/gimg/my350z....72be03a666.jpg |
Choose different options to suit your needs like the Setrab oil cooler core or Mocal.
https://cimg0.ibsrv.net/gimg/my350z....b1c0550a41.jpg |
