MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine (https://my350z.com/forum/engine-365/)
-   -   FS: Redline360: Megan Racing 350Z Headers (https://my350z.com/forum/engine/614911-redline360-megan-racing-350z-headers.html)
Redline360 03-03-2017 09:45 AM
http://www.meganracing.com/uploadima...-SSH-N3Z02.jpg
Click here to order: Megan Racing Headers Nissan 350Z/Infiniti G35 (2003-2006) MR-SSH-N3Z
Application:
2003-2006 Nissan 350Z
2003-2006 Infiniti G35 Sedan
2003-2007 Infiniti G35 Coupe
Specifications & Features:
- 6-2 primary piping design
- 2 3/8" inner diameter outlet
- 1 3/4" width x 1 1/4" height primary runners
- 100% T-304 Stainless Steel with Polished Finish
- Direct bolt-on, increased exhaust flow for improved engine performance
*Fitment note: The driver side header has limited clearance between it and the steering rod/column. Typically if engine mounts have lost their efficiency, it will allow more engine movement than normal and create contact on fully loaded cornering. This issue was unable to be resolved without either 1) denting in the piping to gain clearance or 2) reduce piping diameter to make clearance, however we found the OEM runner size to be the only size that would fit for our design without contacting the steering rod/column.
