LED's Are Finally Here!
SFZCC
on
Originally posted by VQracer
Keep in mind clear set will cost significantly more since the clear lens are already expensive from Japan plus shipping costs.
Victor
Victor
on
Don't wanna be a buzzkill but that link you gave us, it links to someone's account.... I think you can order and charge it to that guy...Should probably remove that link and replace it.
on
Victor
Victor
Any ideas Yuichi? Will you guys make the white ones and how much will they cost?
on
Westpak if you can send us your clear sidemarkers we should be able to do those. Just give me a call.
In Japan the stock sidemarkers are smoked, and they also have the clear ones. We are trying to get both but have been waiting for sometime now unfortunately.
Z461 thanks for pointing that out we have fixed that, it was just a dummy account.
The Lights are supposed to be tapped into the city lights. The first switch out of the two. When you have the city lights or headlights on then the LED's light up. I don't know if there is a source that you can tap into to have them on all the time. I'm sure someone can figure it out. But the City light is the easiest one to tap into without pulling the headlights out.
on
Yuichi, I also have the clear markers. I have no problem removing them and sending them to you. Could give me an estimate on what it would cost to add the LED's.
Thanks.
Victor
Thanks.
Victor
SFZCC
on
Re: :)
If I take them out tomorrow and fedex them how long to get them back?
How much? (I will offer pics for your site )
You don't have to answer here, I will call tomorrow morning.
on
Westpak,
Sure give me a call, we can talk about doing a custom set up for the Clears.
SunsetZ,
Where is this reflector? I'm sorry I don't know which park your talking about. Do you have a picture? Sorry I'm real slow sometimes
SunsetZ,
on
There is a reflector on the lower interior door panel. On most cars this is a light, but on ours it is a reflector only. If we could get a light in there that lights anytime the door is open would make a nice improvement.
on
I wanna set
Hey I am down for that, also if you are getting parts from Japan, are you able to get the Japan Parts Horn for the 350Z, I want that as well & if you can get that I will get them both at the same time.
By the way check out the License plate that I made..
#40
on
Can someone please post a close-up picture of these things with the LEDs turned off. I'm curious to see how clean the LED install is, and what it looks like when not in use.
Thanks,
Mika
Thanks,
Mika
