Daytona Blue Stillen 350Z
Originally posted by nosuchsol
the color is off a bit, but it was a quick job
I am using PhotoShop 7.0 "just started"
Thanx
Originally posted by Loaded_Pistol
Any way you can post steps on how u change car color.
Thanx
Thanx
I'd really recommend checking out a tutorial. I'm far from being good at this stuff. lol. Uh, most tut's should tell you to mask off the area you want to copy - then I fiddle with the hue and saturation on that new layer (use the dropper on the desired color - then colorize and it gets you somewhat there). You can also use the magnetic lasso - then use the polygon lasso to add or subtract from the rough outline(SHIFT+ or CTRL+) =)
I may go to the public library on Mon, and get the tutorial(s) since perfection is the key...
You are getting there tho
Bodyboarder81
09-21-2015 06:23 AM
