problem with lighting
Old Jun 15, 2006 | 04:19 PM
ngynnhu's Avatar
ngynnhu
Default question about wiring neons?
okay i've wired a neon for my sub box to illumiate my sub. it's wired so that when i open the door either passenger or driver the light will turn on. I spliced the negatives to the door trigger wires which are negative and then i place the postive wire to the fuse box where the dome fuse is. It worked fine for couple days but then all of a sudden my windows wont move that initial time when i open and close my doors.it happens on both sides. so it wont seal again when i close the door. I did some checking and when i unplug the spliced wires from the negative wires on the door trigger the windows work fine??? my question is, is there any reason why it's interefering with the windows??? do i need anything additional w/o just splicing into the door trigger wires?
Or is there another place to tap the wires into that will allow the lights to turn on when the doors are open?? I used T connectors to tap into the wires if that makes any difference. any help would be appreciated...
thanks
nhu
Old Jun 16, 2006 | 02:42 PM
ngynnhu's Avatar
ngynnhu
anybody?
Old Jun 16, 2006 | 03:05 PM
THEDUKE's Avatar
THEDUKE
You need to wire them up using a relay. The negative ground when you open the door will activate the realy, but it will have its own power source. The way you are wiring there is a chance for problems.
Old Jun 17, 2006 | 09:06 AM
ngynnhu's Avatar
ngynnhu
thanks duke i will try that
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
