I've searched and searched, need Titek duct template
Maybe make this into a sticky or something? Or put TITEK DUCT TEMPLATE into the title so it is easily found (like I did)?
Anyhow, does anyone have the template for the Titek carbon fiber duct? I got one used, searched for about 15 minutes using several combinations of words and nothing useful is found (Titek, carbon, duct, template, air, intake). Some one want to post a PDF or a 1:1 scale template so I can get to cutting? Thanks in advance. |
1 Attachment(s)
I found that the Titek template was way off. I went ahead and made some changes to the Varis template to accommodate my Titek install.
Follow these steps (I take no responsibility for you adversely damaging your bumper cover): -Print off the file using Microsoft Fax and Picture Viewer -Print as a Full Page Fax Print (first option). This shrinks it enouch to work with the Titek duct since the Varis has a larger "opening". -Make sure the lines match up with bumper and light -Make cuts following the red lines that I added, as squaring off the edges will not work with the Titek. -Be cautious and continue to trim to fit. EDIT: This is meant to serve as a guide, not necessarily a cutting template. Use at your own risk. |
Any luck with this yet?
The bumper is going under the knife this weekend, I'll let you know.
I did open the template, re-sized it in Photoshop to 8.5x11 and it looks close enough. Start small and open the hole up and test fit, repeat until it fits. Thanks again for the file. It really helps with the alignment to the lights and hood seam. I'll post some pics after I finish :) |
Originally Posted by Sponge
(Post 4637852)
| All times are GMT -8. The time now is 03:20 AM. |
