Help! My Cluster Isn't Working!
I started up my car today and noticed none of the gauges in my cluster work and the VDC, low fuel, brake and SLIP lights stay on. The back lights turn on and the seat belt light turns off when I put it on. The only thing I've tried so far is disconnecting my battery for a minute but to no avail. I didn't think it would be fuses since I'm still getting power to it.
Any suggestions before I take it to the dealership?! Thanks! |
1: Try leaving batt disconnected for about 45min - 1 hour, then hook back up. I believe 30min is the min to allow the ECU to reset.
2: Check fuses for cluster 3: Thats all I got, but its worth a shot. Thats a very strange combo of events you have there. |
Originally Posted by GeauxLadyZ
(Post 7787397)
Wow man. Ewww.
Reconnected the battery and nothing. I looked at some old threads about similiar problems but no one said if/how it was fixed. Oh well, looks like a trip to the dealer this week.
Did you search under "maintenance and repair" section?
Yeah and saw some interesting facts about the VDC and Slip lights being on that I didn't know...couldn't find anything on the gauges.
could be a grounding issue, i think in some models there was a tsb about it in the cluster.. ps i have a cluster with 43k on it if you in the market.. good luck though
Take it to a parts shop and see if they will run a free diagnostic scan on it. If it throws a code research that code and go from there. Odds are it sounds like a dealer fix. Could be a lot of different things.
Originally Posted by Globalscan
(Post 7790867)
AdvabZ33 did they tell you what exactly happened? I was installing a new Headunit and my Z did the same thing happened! I know I had to Splice in to the VSS wire connected in the AC controls I am wonder if that has anything to with it!
Originally Posted by AdvanZ33
(Post 7813190)
I took it to Advance Auto and it threw a fuel level sensor code. :dunno: I ended up taking it to the dealer and it was the AC amplifier. I guess they wiring from my AC controls to my gauges are directly related. Anyhow, $600 later everything works fine.
Originally Posted by mw350z
(Post 7903232)
agree
Originally Posted by dkwang
(Post 7903545)
600? Ouuuch. Sorry to hear that man.
Similar situation happened to me except my fuel gauge is reading empty and vdc/ slip light came on the dash and navi screen. I took car off and tried to restart and it just cranked and didn't start. I disconnected battery for about 30min and the vdc/slip light came off but fuel gauge remain to read empty....good part is that it did start up lol
(Post 7903232)
| All times are GMT -8. The time now is 11:42 PM. |
