MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Exterior & Interior (https://my350z.com/forum/exterior-and-interior-51/)
-   -   HID's Replacement? (https://my350z.com/forum/exterior-and-interior/575135-hids-replacement.html)
NickStepanov Mar 20, 2013 05:36 PM
HID's Replacement?
I have an 07 ZR and I need to replace burned out HID...what type do I need to purchase and where would be the best place? Thanks to anybody that helps.
Waiz Mar 20, 2013 08:36 PM
There are several vendors in our vendor marketplace who can assist you with ordering a new bulb
https://my350z.com/forum/body-exteri...-warranty.html
https://my350z.com/forum/body-exteri...-same-day.html
https://my350z.com/forum/body-exteri...-3-days-o.html
K51 Mar 20, 2013 10:05 PM
Don't buy a cheap, Chinese aftermarket bulb. It won't match the OEM in color, and even if you buy a pair, you'll likely suffer in light output and beam pattern. I'd look for a pair of high-quality OEM-type Philips, Sylvania, or Osram D2S replacements, and stick with a color temp of 4300K - 5000K. Here's an example:
EDIT: Sorry, don't know why 2 links are above - they're both the same.
jtabraham Mar 21, 2013 06:16 AM
I installed these last month:
Color is very close to stock, and the reviews seem to indicate a good life. Price is hard to beat too.
shibiscuit Mar 21, 2013 11:37 AM
Hope this helps, pretty sure you're supposed to get HID-D2R for low beam replacements. I had a guy try to sell me H7 bulbs because the salesperson confused "HID Attitude - Halogen bulb inside package" with actual HID bulbs
K51 Mar 21, 2013 01:43 PM
The late-style ('06>) Bi-Xenon HID headlamps each use a single D2S bulb, which serves as both the low and high beam.
NickStepanov Mar 23, 2013 05:49 PM
Thanks guys ill look into it
NickStepanov Mar 23, 2013 06:01 PM
Oh & also the reason why my bulb burned out in the first place is because I was missing the wheel covering under the headlight so water got in it...where can I get the new covering?
K51 Mar 24, 2013 04:23 AM
just posted to your other thread - rockauto.com
