Perfect USB outlet for Center Console (heated seat slot)
Hey guys. I have been searching all over for a USB outlet that can fit where the heated swiches go. I have one blank where I can fit it. Here is what I found but I doubt any may fit:
https://cimg5.ibsrv.net/gimg/my350z....5145de6b99.png |
hi, you can use this:
https://www.aliexpress.com/item/1005003080610626.html it uses the add-a-circuit thing using an empty fuse box slot (at the driver footwell, there are plenty). i believe i had to extend the wires as i couldn't fish it direct shot diagonal under the whole base carpet (there is **** underneath); so i needed length to go around the edge under the carpet by the pedals. here is what it looks like when it's done: https://live.staticflickr.com/65535/...40764367_b.jpg you can also put it at the slot near your TCS off button if you'd like so you don't have to extend wires. it also makes it easier and a much shorter run to feed a usb cable to a dashcam for example. but at that part i put a trunk opening button that i wired up. couldn't really find anyone who did it but it was easy enough the nissan button is all the general same size there's plenty of choices of functions (pictures really) to get. just make sure you get the correct one, as the newer nissans have a different profile (different dimensions, and rounder rectangle) |
