MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Exterior & Interior (https://my350z.com/forum/exterior-and-interior-51/)
-   -   Weird - Maybe the 350Z body isn't very stiff (https://my350z.com/forum/exterior-and-interior/69507-weird-maybe-the-350z-body-isnt-very-stiff.html)
jimster716 Apr 9, 2004 09:16 PM
Ok so earlier today I noticed that there was a dimple on the passenger side roof right above the "b-pillar" where the door meets the body. I thought maybe someone pushed down on it too hard.
But tonight I noticed the same thing on the driver side. Because of the symmetry between sides and that it occurs right above the b-pillar where the doors close into the body, I can only surmise that this is the weak point in the 350Z's body. Not to toot my own horn, but I think regularly autocrossing and HPDEs have actually tweaked the sheetmetal.
I think a chassis stiffening rollcage is in order before something happens that tears the metal. Anybody noticed this on their Z?
mattbruhin Apr 9, 2004 09:18 PM
Plainly, NO
jimster716 Apr 9, 2004 09:20 PM
Originally posted by mattbruhin
Plainly, NO
Thanks for being direct. :D
joust75 Apr 10, 2004 01:36 AM
Did you maybe install a harness bar??
This might have pushed out the B pillars, causing dimples.....
jimster716 Apr 10, 2004 06:10 AM
Nope.
I guess the 275/40/18 tires front and rear, cusco sways, and Tein Flex are too much for the sheetmetal to take. :cool:
Rayden2001 Apr 10, 2004 06:53 AM
Nope.
Can you take a picture of it?
ranger5oh Apr 10, 2004 08:38 AM
I have the same dimple!!!!! I thought I was going crazy. I am glad you noticed it too. Weird, I hadnt thought of it being a weak point, but maybe that what it is. I am going to go look at it a little later and see.
jimster716 Apr 10, 2004 09:06 AM
I have a black car so it's not easy to see it especially on camera. I will try but I can't until next week...Dreamworkes has my car again out here.
aalzuhair Apr 10, 2004 11:49 AM
Maybe the car needs something like a sub-frame connectors.
http://www.mustang50magazine.com/50m...mage_large.jpg
Az
aalzuhair Apr 10, 2004 11:59 AM
I like this one
http://www.totalcontrolproducts.com/..._installed.jpg
or this one
aalzuhair Apr 10, 2004 12:35 PM
Can someone Photoshop one of the above sub-frames to this picture.
Thanks,
Az
http://www.the-top.com/350z.jpg
teh215 Apr 10, 2004 01:53 PM
The piece above both passenger and driver side windows is not part of the structure of the car, it is a plastic finishing plate that you can remove. Is this the area you are taking about? If so, it could just be a defect in the plastic. Or that single screw in that area my be the culprit.
teh215 Apr 10, 2004 01:58 PM
1 Attachment(s)
For reference from the FSM
joust75 Apr 10, 2004 02:10 PM
Nope.
Perhaps maybe welding in a harness bar will hold the B pillars rigid and prevent this from happening to others.
Ranger , can you take a picture of yours? I am about to start tracking my baby and dont want this to happen.....
350ed Apr 10, 2004 04:50 PM
Wow, I never knew that was plastic until now. :eek:
Z350Lover Apr 10, 2004 06:01 PM
I second that!!! You are not alone!!! :eek:
cheers,
richie
rodH Apr 10, 2004 07:41 PM
I have a slight dip on both sides as well, I noticed it a few weeks ago, but assumed it was from someone pressing on it. I also noticed today as my car was jacked up putting my new springs that there are a couple creases in the side skirts as well on both sides.
ether Apr 11, 2004 02:37 AM
this is what i have been considering if i can't find a shop to do a roll cage that i want
http://www.excite.co.jp/world/englis...co=excitejapan
i hope that link works if not use this http://www.rsw.ne.jp and look for reinforce
apsilon Apr 11, 2004 03:48 AM
If the dimple is in that plastic piece (I noticed it was plastic the first time I washed the car) I have it as well. I thought it's probably an attachement point or where it's prssed into place. Mine's only noticeable because the reflection changes over the dimple.
Landbarger Apr 11, 2004 05:14 AM
Thanks ether, your first link didn't work but the second did fine. that really does look like a workable solution from the perspective of a non-mechanically inclined person. Can someone who tracks (anything) comment on whether this works or just looks nice?
