Feedback & Suggestions for Our Forum This is NOT a place to ask car/modification questions!
For posting feedback, suggestions or comments regarding our My350Z.com forum.
G37S/Q60s 6Speed Transmisson Issue
Old 12-06-2018, 10:57 PM
Q60Sam
Q60Sam's Avatar
Default G37S/Q60s 6Speed Transmisson Issue
So I recently came across a problem in my 2014 Q60s 6speed. Never encountered this problem before & can’t find any information on my problem. PLEASE HELP.
If I am driving normally just cruising the car is fine. But if I decide to get into the car a lil banging gears the gears do not catch. For instance if I bang 2nd-3rd rarely would it catch a gear. The issue it does is get very loose. The car will not go into gear at all & if it does go into the gear it’s very very loose. In order to get it back to normal I have to press down as if I am going into reverse. Can someone please help me find my problem.
Old 12-07-2018, 03:19 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
maybe quit driving like a douche, and also learn to post in the correct section. why would you come to a 350z website to ask about a q60?
Old 12-07-2018, 03:33 AM
Q60Sam
Q60Sam's Avatar
It’s a vq dumb ***. Same motor just different body. Get off my dick if you can’t help me
Old 12-07-2018, 03:45 AM
travlee
Master
travlee's Avatar
so why not post in a g37 forum fooktard?
Old 12-07-2018, 04:54 AM
DaveJackson
Master
DaveJackson's Avatar
What does "bang 2nd-3rd" mean?
What does "the issue it does is get very loose" mean?
How will either of these serve as feedback for the forum? (Since that's what sub forum you posted on).
Old 12-07-2018, 07:23 AM
bboypuertoroc
bboypuertoroc's Avatar
Received 2,446 Likes on 1,768 Posts
Your transmission is the same motor?
iideadeyeii (12-10-2018)
Old 12-07-2018, 08:23 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
OK folks, please STOP. Let's not foster a hater environment (worse than it already is.)
OP, I would check your clutch. Doesn't seem to be disengaging fully/correctly under high speed load. If the clutch itself isn't at fault, very likely the hydraulic system isn't keeping up. Nissan never did quite fix the inherent CSC issue. Bad design.... or OK design, poor execution because the Z Speed HD replacement works fine.
rustyschopshop (12-10-2018)
Old 12-10-2018, 11:56 AM
Legacy406
Legacy406's Avatar
Received 3,273 Likes on 2,574 Posts
Stop driving like an idiot for starters.
travlee (12-10-2018)
Old 12-10-2018, 12:58 PM
iideadeyeii
iideadeyeii's Avatar
Screw your shift **** in a full turn. . .or out. (I don't judge)
Dhred
04-25-2011 11:57 AM
350 Rookie
08-15-2008 11:13 AM
Mps350z
05-22-2007 08:51 PM
Quick Reply: G37S/Q60s 6Speed Transmisson Issue
