MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Feedback & Suggestions for Our Forum (https://my350z.com/forum/feedback-and-suggestions-for-our-forum-84/)
-   -   350z Key fob won't program (https://my350z.com/forum/feedback-and-suggestions-for-our-forum/627619-350z-key-fob-wont-program.html)
JuicenoTenshi Apr 4, 2023 05:40 PM
When I go to program the key fob I do everything as told I've looked at a lot of different forums about what to do and none of them work
When I go to program I lock the doors either the bottom or on the handles I then insert the key in and out about 12 times until the hazards flash When they do I put the key in and to accessories mode and press/hold the unlock or lock button on the key fob then the hazards flash so I take the key out unlock the doors by the handle or button then I open the door and press the button on the key fob and nothing happens.
Does anyone know what to do, I'm going to try buy a new battery soon.
Heel Til I Die Apr 5, 2023 05:17 AM
When performing the locking/unlocking steps, you should be using the power switch and not manually at the handle. Other than that, it should work.
i8acobra Apr 5, 2023 07:06 AM
If the remote won't learn, then you may have too many remotes in memory. You may have to clear the memory to erase all the remotes and start fresh. I can't remember the max number of memory slots. I also don't remember how to erase all of the remotes. At the dealership, I'd just use the Consult 3 to do it.
JuicenoTenshi Apr 6, 2023 08:30 AM
I think that might work it would make since ill try that out when I get the chance to.
