PE 510's on HKS SC
I have a set of PE 510's and was wondering if I remove the 2 aux injectors and install the 510's will I be able to start the car and drive it around. Basically will the stock ecu be able to run these injectors on cold start/idle and cruise. All I want to do is install the injectors and then drive to the shop so I can get my FCON tuned. Want to save some $$$ as I can do the install myself.
Dont the two aux. fuel injectors only come on when boosting ? If so , you shouldnt have a problem . If you boost it on the way . You will just go rich as hell ....no biggy
I will be removing the 2 aux injectors while installing the 510's. All I'm trying to find out is if the car will start and run okay.
Oh...I see . I thought you was replacing the aux. injectors WITH the 510's....sorry
If it hasnt expired. |
LOL.. Unfortunatly I think it has. Had the car for 3 years now
| All times are GMT -8. The time now is 05:56 AM. |
