HELP! I'm only getting 2 psi of boost
I just finished installing the APS TT on my 06 last night. Took it for a spin and was only getting 2 psi max on my autometer boost gauge and my zeitronix display. Basically, the car drove just like stock. I'm positive it's not a boost leak because I didn't hear any unusual sounds indicating a leak. I think my actuators are messed up and not holding boost. :(
Any ideas? :confused: |
Check boost selonoid wiring.
you got a leak
Originally Posted by BoOsTedz33TT
you got a leak
Originally Posted by Nismo350ZRT
Wouldn't a boost leak of that size be very audible?
Double check all charge pipe couplings...
also check your wastegate
I hope you guys are right and it's only a leak. I'll check all the couplings tonight.
if you are running cats and/or stock exhaust, spring pressure would be very low. that said, 2 lbs seems abnormally low. |
reason why is best to let a pro take care if this kinda stuff
Originally Posted by Zivman
I would bet you don't have your solenoid properly wired. It is definitely a possibility that you have a leak, so also check for that.
So unless the springs are set for 2psi boost, which seems very unlikely, this isn't it, right? -E |
Originally Posted by -EL
I'm not sure how he could have the solenoids wired wrong to cause this problem. If he had it wired wrong and they were always opened, he would get whatever boost the wastegate spring was set to, and if he had them wired wrong and they were never open, he'd get as much boost as the turbo could give, since the wastegate would NEVER open. Anything else would be something in between those extremes.
So unless the springs are set for 2psi boost, which seems very unlikely, this isn't it, right? -E I think he doesn't have the boost solenoid wired properly. Maybe set to ground instead of power, maybe something else entirely. With a restrictive exhaust and cats, spring pressure might only be a measily couple pounds. |
Check the intercooler couplers, they can be hard to get just right because they are so short. One could have popped off.
I had the same problem after I got my stillen radiator installed and it turned out that one of the couplers got loose.
Check all the couplers |
I checked all the couplers and they're all connected and tight so no obvious leaks. I visually inspected the wastegate actuators and they look fine. I pulled on the actuator arms and they're tight so the springs aren't broken. I checked the blow off valve and the valve is shut tight so no leak there. I'm not sure what else to check at this point. :confused:
-E |
| All times are GMT -8. The time now is 04:30 PM. |
