MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Forced Induction (https://my350z.com/forum/forced-induction-182/)
-   -   Here's my TT set-up plan. Help me with any other additions please. (https://my350z.com/forum/forced-induction/201434-heres-my-tt-set-up-plan-help-me-with-any-other-additions-please.html)
AParshall04 Jul 3, 2006 01:22 PM
Sorry to be posting so many threads lately, hope you guys don't mind. I just want to have everything together when i do the installation.
I committed to buy a PE TT Kit form forum member turismo, havn't paid him yet because it's still coming off the car.
Here's the set-up so far:
PE TT Kit
Walbro 255 fuel pump
Tial bov
Crawford Nav cubby dual gauge pod
digital boost gauge (reads a digital # without a needle, but is 52mm)
AEM UEGO wideband
NGK LFR6AIX-11 1-step colder spark plugs
Turbo XS dual stage Manual Boost Controller
Service manual
New oil filter/new oil
New power steering fluid
New Radiator fluid
extra vacuum tubing
BEER
Anything else i need? I was thinking of a turbo timer maybe.
z350phille Jul 3, 2006 01:43 PM
How abouit a clutch for the power you will be making after install... :)
bmac03z Jul 3, 2006 01:45 PM
sig says jwt flywheel/clutch
MoodDude Jul 3, 2006 01:48 PM
Make sure you get an Oil cooler on that beast!
Tune!
Some other options:
Exhaust?
Test Pipes?
EGT's?
Upgade the brakes and tires (you are going to be going a whole h@ll of lot faster after TT)?
Does the PE TT come with larger injectors?
Gman2004 Jul 3, 2006 02:10 PM
I don't have any experience with the Tial BOV, but I've been told it doesn't work well for smaller turbos. For larger Supra sytle turbos they work better.
Also what are you using for EMS?
AParshall04 Jul 3, 2006 02:12 PM
Tune!
Some other options:
Exhaust?
Test Pipes?
EGT's?
Is an oil cooler really necessary?? Isn't that for people drifting or auto-x'ing
Exhaust - going to stick with stock for a while.
Test pipes - i live in CA
EGT - you mean the gauge? I think i'm chill with a wideband for now
Brakes - hawk pads are enough for me right now
Tires- i have 18x8.5/18x9.5 rims with toyo t1-s's all around, should be good.
As someone else mentioned, i do already have a clutch/flywheel
MoodDude Jul 3, 2006 09:38 PM
EGT - Exhaust Gas Temperture
When you upgrade power on the engine - you also need to upgrade your cooling and the best way to do that is an oil cooler. If you search, you will find many people who have concerns about tempertures in stop and go traffic during the summer with a TT and solve it with an oil cooler - cheap and easy to install.
knight_white99 Jul 3, 2006 09:45 PM
If you are going to track your car, you want BOTH a bigger radiator and an oil cooler.
AParshall04 Jul 4, 2006 01:30 AM
No tracking. Mostly just driving around town.
Maybe i'll go with an oil cooler down the road sometime just for safety.
As far as EGT goes - i know what the acronym stands for, and i know you monitor it with a gauge. I just don't see the need for the gauge if im only going to be runninga bout 5psi.
knight_white99 Jul 4, 2006 07:42 AM
If you are going to have a wide-band, I guess I agree that an EGT is not a requirement, especially if you are only going to run 5psi of boost.
A good tune is a must though. I have heard too many horror stories of folks who slap on turbos or SC's and drive off, only to have their engines blow up in very short order.
MoodDude Jul 4, 2006 07:52 AM
That is why I said EGT's would just be a good idea but not required.
I still believe an oil cooler is needed no mater if you just drive on the street or the track. Do a search and you will find many people with TT with oil temp problems in stop and go traffic. They solve it by installing an oil cooler.
I agree you don't need a larger radiator unless you track the car.
AParshall04 Jul 4, 2006 12:21 PM
Alright well you've convinced me. I'll be buying one soon. Driving home to San diego i hit LA traffic, never know what could happen.
Gman2004 Jul 4, 2006 01:32 PM
I can't believe this has been overlooked and that no one has asked about EMS. What are you going to use to tune your kit?
turismo Jul 6, 2006 06:21 AM
I made 412rwhp at 7.5 psi of boost with stock computer. PE says you dont need to upgrade the stock ecu until 9psi. I had mine running for over 6 months without a problem.
Alberto Jul 6, 2006 07:27 AM
Nice numbers. Is this with a reflash? What injectors? Curious what was your TQ?
G.Ride Jul 6, 2006 07:57 AM
you've heard right. The TiAL will work ok on lower boosting turbos, but its built for high boost. It can handle a lot of pressure. Its a really nice bov. At least its not loud like the RFL.:icon18:
G.Ride Jul 6, 2006 07:59 AM
Absolutely!
An EGT gauge is a must. EGT spikes are one the causal agents of detonation.
Alberto Jul 6, 2006 08:17 AM
OT-but Ive found that most who own an EGT dont even know what those spikes mean. G.Ride-do you know what it would mean if at WOT your EGT's spiked 300 degrees hotter than normal? And dont tell me "Id just let off the gas" do you actually know what is likely causing it? IMO-a good wideband is better for most...
G.Ride Jul 6, 2006 08:21 AM
Alberto, thats part of the problem... There could be mutiple things that can cause those EGT spikes and mutiple things that can happen because of those spikes. I guess its just a good safety feature. I dont argue that wide band isnt beneficial. I am just as much a fan of Wide O2 as I am of EGTs.
vq35carel Jul 6, 2006 09:27 AM
pm me if you need help
I have the PE kit making 585 rwhp on my 04 350z
