Latest pics of my engine
Old Aug 27, 2006 | 08:47 AM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by supra crazy
Is there no water pump?
the water pump is run off the backside of the timing chain under the timing covers! thats stock tho, not my idea The water pump is located just behind the black removable panel on the timing cover that is to the upper/right of the crank pulley.
Old Aug 27, 2006 | 08:57 AM
phunk's Avatar
phunk
CJ Motorsports
notice that along with the removed factory oil/water heat exchanger, I got rid of the lines for it. If you look you can see in one of the pics the thermostat housing, the nipple for the oil/water heat exchanger was removed and we drilled and tapped it to put in a NPT plug. At the otherend, on the large pipe on the pass side, we just cut the nipple off and welded it shut. Did the same thing for the throttle body cooling lines, cut off the nipples and welded everything shut.
like everything else, this was done to clean up the bay and make it all easier to work on. i am also hoping that there is a minor side benefit of more of the coolant being forced to take its path thru the block/heads, rather then having 2 easy routes around it.
Old Aug 27, 2006 | 02:11 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
damn man, we think a like.... get rid of all the stupid **** and make it simple and easy to work on!!
Old Aug 27, 2006 | 02:47 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Love those oil feed lines.
And thank the lord....I love your new digital cam!!!!!!!!!!!!!!
Old Aug 27, 2006 | 05:03 PM
Peking's Avatar
Peking
Yeah the pics are so clear, what camera Phunk?
Old Aug 27, 2006 | 05:22 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Looks good Charles...hey...(besides the issue with fitting them through stock size head holes) how do you like the 1/2" studs? What did you end up torquing them down to?
-TODD
Old Aug 27, 2006 | 08:06 PM
phunk's Avatar
phunk
CJ Motorsports
the camera is just a little Nikon coolpix L4, its my girlfriends, she got it for like 150 bucks a while ago. those pics are after i used photoshop to cut the res in half and also saved at 60% quality.
Old Aug 27, 2006 | 08:07 PM
phunk's Avatar
phunk
CJ Motorsports
-TODD
so far so good, we will see when i start boosting tho!
running them thru the stock holes in the head wasnt bad after i put molylube on the shaft of the stud, it hid the friction well enough that it was easy to tell when i bottomed out. snug fit, but it worked
I am confident that they are going to withstand the test of time and HP here, with those HKS headgaskets especially make me feel better.
I torqued them to 100ft lb.... that should be sufficient. Its one of those mods that I feel if your engine is already out, your better off just going to the larger studs, its only gonna help.
BTW guys I sent Todd @ BuiltZMotors.com my engine to do the 1/2" headstud conversion.
Old Aug 27, 2006 | 08:10 PM
phunk's Avatar
phunk
CJ Motorsports
talk about the never ending project... i still didnt fire it up today. hoping to tomorrow now!
Old Aug 27, 2006 | 08:21 PM
G352NV's Avatar
G352NV
**** looks clean! Nice job!
Old Aug 27, 2006 | 08:49 PM
norapat01's Avatar
norapat01
Mitsubishi Turbo? I heard the rumor which said that Mitsubishi is making turbo for every company in Japan is true....
Old Aug 28, 2006 | 05:17 AM
mcderns's Avatar
mcderns
Looks awesome Charles! Cant wait to see it in person!
Old Aug 28, 2006 | 09:28 AM
Quamen's Avatar
Quamen
I remember seeing something about the PS relocation kit on your site. that is exactly what I will be doing to my car here in the near future except I will hopefully be able to position the PS and the alternator on the driver side in the correct position. I have a feeling the PS may be a bit trickey so I may end up ditching it.
Old Aug 29, 2006 | 07:52 PM
phunk's Avatar
phunk
CJ Motorsports
brandon and i mounted the oil cooler behind the intercooler since I have no AC condenser there. We will see how the oil temps behave.
I fired up the car today, started right up.
Should be on the road this weekend, waiting for stuff from Nissan.
Old Aug 30, 2006 | 03:29 AM
Audible Mayhem
My350z
nice man!!
Old Aug 30, 2006 | 06:05 AM
Sharif@Forged
Forged Performance
Sorry if I missed it earlier, but are you running your new twin pump setup, or still the StageI-StageII system. Can't wait to see the results man...you car has been a long time coming.
Old Aug 30, 2006 | 06:51 AM
oorx7's Avatar
oorx7
Vendor - Former Vendor
True. But building oil pressure, now that was a fun.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
