will pulley set work with tt set-up
hey guys im getting the orthodox pulley set i was wondering if i go twin turbo will the pulley set work in unicen with the turbo or would i have to get rid of the pulley set, thanks.
Unison
thanks, now can some one answer my question please!
yes .. i run UD pulleys on my car
it will work, but i personally don't recommend it. the lighter solid crank pulley has no dampening abilities. dampeners are designed to absorb the twisting harmonics created by the piston firing, it is a situation that will amplify with more power. not worth the risk in my opinion.
unless you get a dampened unit. which i amnot sure they make for the Z |
ask any engine builder and they will tell you that those crank pulleys do not have harmonic balancers and they can cause harm. But they can be used with any TT kit, just ask yourself if its worth it?
this is what I use http://store.summitracing.com/egnsea...DS=1&N=700+115 |
our zs do not have harmonic balancers.
I've always liked this saying:
Just because you can kick an old man down a flight of stairs, it doesn't mean that you should... |
