How lean does adding test pipes actually make the AFR mixture?
Old Nov 2, 2007 | 09:41 AM
moog's Avatar
moog
Default How lean does adding test pipes actually make the AFR mixture?
Just wondering if there is an average number like from 11.0 to 11.5 after adding test pipes.
Old Nov 2, 2007 | 11:01 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Stock boosted not boosted what mods any info?
Old Nov 2, 2007 | 11:20 AM
izmir41500's Avatar
izmir41500
he has vortech
Old Nov 2, 2007 | 11:24 AM
Canadian's Avatar
Canadian
I've actually been wondering this myself. Can anyone chime in? I'm on JWT 530bb kit at 7 lbs
Old Nov 2, 2007 | 11:51 AM
moog's Avatar
moog
Vortech
3.12
440 injectors
walbro
plenum spacer
y-pipe
fuji exhaust
Old Nov 2, 2007 | 11:55 AM
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
there's no def answer...the free'r flowing your exhaust gases are, the leaner you'll be. If you're 12.5:1 now, you could see up to a point and a half higher which means you'll need to pull more timing...what are you boosting, 8lbs?
Old Nov 2, 2007 | 12:01 PM
moog's Avatar
moog
8lbs
Old Nov 2, 2007 | 12:05 PM
GlenRoseFireFighter
Originally Posted by moog
8lbs
have you had it tuned? Also, are you reading AF from the tail-pipe or cat? I've seen up to half a point dif between the two. Richer at the cat than at the tail-pipe.
Old Nov 2, 2007 | 12:06 PM
GlenRoseFireFighter
I had kinetix cats on my G and they worked GREAT...actually, they still do, just not mine anymore.
Old Nov 2, 2007 | 12:11 PM
moog's Avatar
moog
It's been street tuned to around 11-11.5 AFR. The reading was taken from the cat.
Old Nov 2, 2007 | 12:16 PM
DanielW's Avatar
DanielW
I went from hfc's to TP's and it only leaned me out like .2-.3
Old Nov 2, 2007 | 05:05 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
+1
Old Nov 2, 2007 | 05:46 PM
tig488's Avatar
tig488
ditto
Old Nov 2, 2007 | 06:26 PM
superchargedg's Avatar
superchargedg
Damn Noobs
What we dont know is he coming from stock cats to test pipes......if he is he will def run lean......at least that is what my tuner said and i trust his knowledge.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
