Custom CAI for vortech charger!!!!!????
Old Apr 9, 2008 | 08:35 PM
jtgli's Avatar
jtgli
Mine is 3.5 and scales down to 3" There is no performance difference. The amount of air getting pulled into the charger is not going to be hindered.
Old Apr 10, 2008 | 07:00 AM
eez's Avatar
eez
I hacked up my Injen CAI to build mine. I don't have any pics though.
Old Apr 10, 2008 | 11:47 AM
chaparro78's Avatar
chaparro78
is it all just for looks? any added value? is it protected from water?
Old Apr 13, 2008 | 03:00 PM
eez's Avatar
eez
did some work this weekend and had a chance to take some pics of the modded injen.
Old Apr 13, 2008 | 03:06 PM
Lawy'dU's Avatar
Lawy'dU
none of these look like cai's for the vortech. They just look like the filter placement for the single turbo setups, which are not "cold air" setups. If you want to see a true CAI setup for the vortech check out gtm's thread featuring their recent build of a 500 whp car.
http://g35driver.com/forums/showthread.php?t=214225
Old Apr 13, 2008 | 03:22 PM
eez's Avatar
eez
why not?? The filter isn't located in the engine bay so it's not pulling hot air into the intake. My filter placement is very close to where it was with the injen CAI, but a little higher because of the intercooler. Anyway the real benefit on the vortech is ease of cleaning the filter.
Old Apr 14, 2008 | 07:00 AM
str8dum1's Avatar
str8dum1
what did you use to cut the bumper brace? its just cut in the back to fit the extra height on the IC, right?
Are you still using the stock charge piping?
Intercooler dimensions are 31" x 12" x 4" I do not have any straight on shots of it however right now. You'll have to remove your bumper to change the filter, but hey, that beats taking apart the charger assembly anyday. Check your PMs also.
Old Apr 14, 2008 | 07:22 AM
taurran's Avatar
taurran
I disagree. The place you pointed out on the G is the same place that the ST kits on G35's usually route their intakes, but both spots are "cold air" locations as they are both before the radiator.
I think you're disagreeing just to be disagreeing, because both achieve the same results.
Either way, I doubt if youll see much of a gain, if any, by rerouting the vortech filter.
Old Apr 14, 2008 | 08:40 AM
jtgli's Avatar
jtgli
My friend actually cut the brace for me @ his work. I just marked off where to cut it. Yes, its cut to fit the extra height of the new i/c. Yep, still running the stock i/c piping as well.
Old Apr 14, 2008 | 08:50 AM
jtgli's Avatar
jtgli
Also, today we just made another intake setup for the vortech on my brothers car. It is a more "cold air" type setup since we have the filter located right next to the intercooler. Here is a pic of it.
350Z_Al
Oct 29, 2020 07:44 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
_bit
Oct 2, 2015 07:49 AM
