Spark Plug tubes: anyone replace them yet?
I have a constant battle with oil filling my spark plug tubes and its extremely annoying. I have already tried to RTV the balls out of the valve cover and the seals around the tubes and I have stopped the leakage on all but one. The tube looks to be slightly damaged due to poor packaging during the shipping of the heads.
http://www.courtesyparts.com/betasit...7-p-15326.html you can buy the tubes but has anyone actually replaced them or know how much labor is involved, i can do it if a press isnt involved thanks, Jason |
Originally Posted by Blackbird CPV35
(Post 6347587)
after installing my Vortech my Spark plug gaskets gave out... They were filling up with oil in seconds..... Its at the stealership now getting the valve covers replaced and its warrantied... I am still fighting to see if my compression is indeed good or not but that is another story..... go see if you can get them replaced if you have warranty left..... the seals on the valve cover are permanent kinda like your rear main.... they are covered....
Z valve covers FTMFL!!!!
11095 are the metal tubes that get pressed into the heads. Your problem most likely lies in the valve cover seals which seal against the tubes. I believe they are built into the valve covers.
I have a valve covers, if you need them LMK.
Edit: i'm located at michigan, you can pick them up if you want. |
Originally Posted by Hal@IP
(Post 6348008)
Have you ever tried to remove a tube Hal? |
Update: Im retarded and everything is in the FSM, apparently you are supposed to replace them every time you disassemble the head
http://i38.tinypic.com/20a3u6u.jpg http://i38.tinypic.com/295bewg.jpg |
Just a heads up, they can be difficult to pull out. Also, mark the new ones height before you put them in because you can go too far. A rubber mallet or block of wood and hammer will work. Just make sure they go down straight and cover everything if using wood haha.
(Post 6349947)
Bump, I am trying to remove the tubes now and I am having a hell of a time trying to get them out Has anyone actually removed the spark plug tubes? Tips please? |
(Post 7027725)
Has anyone actually removed the spark plug tubes? Tips please? +1 on damned stupid valve cover replacement for seals too. I hate having to tell a customer how much that costs. |
Originally Posted by UpRev
(Post 7027847)
Anger works. I've seen them removed with much anger here at the shop before.
+1 on damned stupid valve cover replacement for seals too. I hate having to tell a customer how much that costs. did they use channel locks or anything on them? |
(Post 7027866)
so basically im just being a pussy,
if you could will you ask one of the techs the technique for removing these suckers
(Post 7028011)
I know I've personally yanked out a number of smaller press fit steel vacuum tubes from aluminum intakes using vice grips, but nothing of this size. And I can't imagine having to try and drill it out if the tube cracks or rips. So he must have used some tool I haven't seen sitting around the shop, or he just totally winged it and went with the vice grips. |
Trying drilling the tube and sticking a screw driver in there. Step on the head and yank on the screw driver.
Or try crushing the tube so theres less tube/wall contact. |
Originally Posted by 350 Rookie
(Post 7029562)
Or try crushing the tube so theres less tube/wall contact. I was acually gonna try drillin it laterally tonight. I just gotta be careful with all the metal shavings |
I have only installed them on the cosworth heads (don't come with them for some reason...) But it is just a pressure/interference fit wit the head. I would use vise grips and a propane torch to heat the head up uniformly with the engine cold. The allum should expand faster than the steel tube and you should be able to twist/lift the tube out with the vise grips, getting mad at them will help also!
seriously **** my life lol
i tried drilling them and twisting them out and it didnt work even tried looking a hook through the holes and using a cherry picker to try and pull them out and the damn thing picked up the whole engine just shoot me now |
bump, UpRev did you ask your tech about this yet?
