Blown Motor=Blown Turbo?
This person has a APS Extreme TT kit on a stock block.
His tuner ran 22psi on a stock block, pretty much grenaded his motor. I told him the turbo are pretty much shot since all the bearing and metal material from the motor blowing is passing through oil system which also lubricates the bearings on the turbo. right or wrong? |
You are correct sir.
Surely some small pieces made it through the oil system...and depending how long it ran, got passed to the turbos. So turbos should be rebuilt without a doubt. btw...22psi on an APS Extreme kit.....that is capable of around 650-700rwhp right there......lol Tom
Originally Posted by Glex25
(Post 7907995)
Who's the tuner?
^^ +111111111111
Logic is correct, but they may not be blown. The extent of the damage may never be "felt" or it may be seen immediately if the kit is used again.
that tuner needs to be shot, 22psi on a stock block? :icon22::icon14:
Don't know him or the shop name.
He wouldn't say and not someone I would use anyway The aps extreme comes with a 14psi wastegate spring that should have been the first thing that should have been changed to a lower psi spring to have it run on a stock block. Supposedly the tuner did not have the application to tune a unichip that was warning number one. I told the guy to get out of there and take it elsewhere or at leas tupgrade to Utec. Warning number 2 tuner telling him a SS Box is better than a unichip or utec. I feel sorry for the poor guy but he won't take my advice They telling him that the turbo's are still good |
Doesn't sound like much of a tuner to me .....
"They telling him that the turbo's are still good" Is "they" refering to the shop that just blew his motor???? Sounds like this guys a lost cause....I mean they blew up his motor ( I would almost say intentionally ) and then he's going to believe them when they say his turbo's look good ...... :dunno: PLEASE warn everyone where he went!! |
I would love to see what the motor looks like....
Did - a) the fuel system give up first and it melted EVERYTHING in the cumbustion chamber, or b) it made tq just long enough to discinegrate the rods, or c) it just punched holes through the pistons as detonation took over tom
Originally Posted by Blck350z
(Post 7908055)
(Post 7908047)
He wouldn't say and not someone I would use anyway The aps extreme comes with a 14psi wastegate spring that should have been the first thing that should have been changed to a lower psi spring to have it run on a stock block. Supposedly the tuner did not have the application to tune a unichip that was warning number one. I told the guy to get out of there and take it elsewhere or at leas tupgrade to Utec. Warning number 2 tuner telling him a SS Box is better than a unichip or utec. I feel sorry for the poor guy but he won't take my advice They telling him that the turbo's are still good Hmmmmm....Could this shop be somewhere in the westcoast? In the SD area?? Only one person I know thinks the SS box is the best.:dunno: |
Originally Posted by thom000001
(Post 7908105)
Did - a) the fuel system give up first and it melted EVERYTHING in the cumbustion chamber, or b) it made tq just long enough to discinegrate the rods, or c) it just punched holes through the pistons as detonation took over tom He donating the motor to me since there is a hole on the block. Going to use it as a practice motor taking it apart and putting it back together to get ready for my build. Mike all I know is that shop is in NYC. Possibly Queens since he said it it was near the Whitestone Bridge. That is as much info as I could get from him |
Was it RA? :hehehe:
(Post 7908105)
Did - a) the fuel system give up first and it melted EVERYTHING in the cumbustion chamber, or b) it made tq just long enough to discinegrate the rods, or c) it just punched holes through the pistons as detonation took over tom I bet the timing was whack too. |
Glex - Trust me on this - EVERYTHING IS DONE. Unfortunately I am an expert in this particular failure. When my bearings went, the car was shut off almost immediately both times and still I lost everything.
It goes deeper than most think: Cams, headwork, pistons, turbos, crank, oil pump and timing chains - its all garbage. The first time I thought the turbos may have survived, but drain them completely and then spin them. Mine felt smooth till I did that and then they felt like they were full of sand :icon27: |
Well in the OP's situation he may be lucky he threw a rod rather than die a slow death from day 1 due to incorrect tolerances and oil starvation.
Hopefully the rod gave out so quickly the bearings and other components had little time to puke into the oil. |
Hmm.... I think I might now the shop. If it is a tunning shop, and not just a garage.
Originally Posted by Cass007
(Post 7908408)
It goes deeper than most think: Cams, headwork, pistons, turbos, crank, oil pump and timing chains - its all garbage. The first time I thought the turbos may have survived, but drain them completely and then spin them. Mine felt smooth till I did that and then they felt like they were full of sand :icon27: I was thinking of your situation when he mentioned what happened. From what he has told me the tuner is getting him a motor and he mentioned he is moving on to a GTM kit so I'm guessing they are partially covering that too. When he mentioned that they said the turbo's were still good first thing in my mind was that they trying to cover their @$$ and not try to pay for a replacement turbo. |
(Post 7908150)
I should be hearing from the Rastaman real soon:) |
Originally Posted by XKR
(Post 7908139)
i get your logic here..... but i highly doubt its who you think it is. i know hes smarter than that. ....way smarter. |
FWIW I've had a pretty decent amount of experience with turbos and just because their is bearing material in the CHRA doesn't mean the turbo is bad. You can just flush it and it usually ( most of the time anyways ) feels smooth again and will work just fine.
BUT ( and this is a big BUT! ) the problem isn't really the bearings themselves...but any material that may have been sent through the exhaust that would most certainly destroy the turbine wheels. If the car lost a piston ( or more than one ) or a valve then the turbos are more than likely toast! |
