Homemade Vortech pulley mod.
Old 05-18-2010, 03:54 PM
GT-ER
GT-ER's Avatar
Default Homemade Vortech pulley mod.
$47 and boost went up 1.5psi....WEEEEEE!!!
Old 05-18-2010, 04:00 PM
cdoxp800
cdoxp800's Avatar
Nice job and looks great.
Old 05-18-2010, 04:01 PM
Mike@Blackline
Mike@Blackline's Avatar
how is it done?
Old 05-18-2010, 04:04 PM
iStan
ZR
iStan's Avatar
Old 05-18-2010, 04:15 PM
GT-ER
GT-ER's Avatar
Originally Posted by Mike@Blackline
how is it done?
1) Buy the smallest idler pulley you can find.
2) Loosen belt.
3) Mark where you want the pulley.
4) Drill a hole that goes through the SC plate.
5) Put enough washers to center the pulley over the belt ( I used 4 thin ones).
6) Pass the bolt from one side to the other and use a locking nut.
7) Tighten belt.
That's it.... 15 minutes tops.
Old 05-18-2010, 04:54 PM
tylerxfire
tylerxfire's Avatar
not uderstanding why ur boost would go up unless u had belt slip before???????
Old 05-18-2010, 05:11 PM
GT-ER
GT-ER's Avatar
Exactly, and my belt was super tight before.
Old 05-18-2010, 05:14 PM
str8dum1
str8dum1's Avatar
although expensive, I think an ATI or FLuidamper crank pulley is the best way to eliminate belt slip. bigger OD means more belt wrap so you dont have to tension the belts so tight.
but thats a great DIY pulley mod.
Old 05-18-2010, 06:54 PM
binder
binder's Avatar
ford focus runs a 57mm pulley which is just a tiny big larger than gtm pulley.
I have a 60mm pulley from carquest on mine and it works great. Drill a hole, tap, use.
I used a left over spacer from my vortech kit (for another pulley i didn't use) for hte proper backspacing.
Old 05-18-2010, 07:49 PM
GT-ER
GT-ER's Avatar
This was the smallest pulley I could find at autozone, it fit great though so I just bought it without even looking anywhere else...lol.
Old 05-19-2010, 02:02 AM
HotRodG35
HotRodG35's Avatar
The GTM pulley MOD is a mitsubishi timing belt idler pulley. I purchased one off EBay shipped to my house for $25.00 plus a few bucks for the fasteners.
Old 05-19-2010, 09:59 AM
binder
binder's Avatar
make model year of that car and all.
the timing tensioner pulley for a 2003 ford focus is pretty small too.
Old 05-19-2010, 10:33 AM
iStan
ZR
iStan's Avatar
Wouldn't something like this work?
Link
Old 05-19-2010, 10:51 AM
GT-ER
GT-ER's Avatar
Link
It doesn't say what size it is...I could stay under 3".
Old 05-19-2010, 11:03 AM
iStan
ZR
iStan's Avatar
I've been having trouble with getting sizes. I need to contact Hayden and Goodyear and see if their part numbers can be deciphiered into sizes. I saw a few labeled 76mm, but that is much bigger than I care for.
Old 05-19-2010, 12:24 PM
GT-ER
GT-ER's Avatar
Ideally it should be about 60mm or smaller. Mines probably larger, I have yet to measure it though.
Old 05-19-2010, 12:34 PM
iStan
ZR
iStan's Avatar
I'm a jackass. I should have just done a search for a xxmm idler pulley. Here is a 50mm
GATES Part # T42028
Old 05-19-2010, 12:47 PM
GT-ER
GT-ER's Avatar
Hmmm...nice. If mine ever fails I'll get that one...or maybe I'll get it anyways and put it under the larger one...
Old 01-08-2017, 10:39 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Just a quick bump, I will be doing this on install
Old 01-09-2017, 07:14 AM
Z33Garage
Z33Garage's Avatar
Could you not have put an spring idler tensioner pulley instead? That way it dynamically tightens and loosens the belt.
Quick Reply: Homemade Vortech pulley mod.
