GTM Performance Engineering VQ45VHR-Our Journey to The 1000 HP and Beyond
Old 06-19-2010, 10:07 PM
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Default GTM VQ45VHR Stage 6 TT: Project White Dragon
" Project White Dragon "
Pioneer – The word itself conjures thoughts of everything from heroic settlers blazing trails into the unknown to brilliant engineers on the bleeding edge of technological wonders. We at GTM Performance Engineering consider ourselves one of the foremost Nissan VQ platform pioneers in the world. From our groundbreaking work on the VQ35DE that set the bar at 855 wheel horsepower and 820 wheel torque to being the very first to research, develop and manufacture internals, stroker kits and forced induction applications for the VQ37VHR, GTM Performance Engineering has paved the way for enthusiasts to ascertain performance products that are superior, cost effective, and most importantly – results driven.
Not one to rest on our laurels, we at GTM are moving into uncharted territory with what will be the very first four digit horsepower Nissan 370Z. Though this type of challenge may seem simple on the surface, this thought process belies the truth of the incredible amount of research, knowledge and dedication necessary for successful completion of such a massive undertaking. Changing the aspiration of an OEM car, while adding nearly four times the amount of horsepower, requires reverse engineering of nearly all systems on the vehicle and development of custom applications that will not only support the newfound power levels, but will also maintain similar characteristics and drivability of the original product.
One of the key aspects in an extraordinary build such as this is the Engine Management System. Absolutely nothing is more important than the safety and reliability of the power-plant that will be the heart of a 1000 plus horsepower beast. Chosen for this arduous task is the well known and proven HKS F-CON V Pro. To date, GTM Performance Engineering is the only organization to successfully tune the VQ37VHR with VVEL using this superb management system. Though the sheer magnitude of tuning such a complex build is daunting, the outcome will be the same as our previous endeavors – pure success.
After having decided upon what EMS to utilize for the safest and most reliable tune, we directed our attention towards the engine. Mating the EMS with the appropriate power-plant is of the utmost importance when considering all facets of an extremely high horsepower build. Our goals left us with only one choice – the GTM Performance Engineering VQ45VHR. Comprised of the GTM Hi-Rev 4340 chromoly high tensile steel alloy billet crankshaft with 96mm stroke, GTM spec Arias Stage 2 pistons, GTM billet rods and 100mm bore Darton MID sleeves, this 4.5 liter beast of an engine is still OEM enough to allow for the usage of the VVEL system. And when coupled with the GTM Stage 6 Twin Turbo kit, it exacts massive amounts of power.
Given our forward thinking at GTM Performance Engineering, one glaring hole was painfully obvious with this setup – 1000 plus horsepower in a Nissan 370Z will absolutely overpower any suspension and/or rubber available for it resulting in massive traction loss issues. As this project car will be street driven upon completion, lack of traction and usability were not options. Enter the GTM PNP Racelogic Traction Control system. Being that maximum acceleration is achieved by limiting the slip between the tire and the road, the Racelogic TC system works by monitoring the speed of all four wheels using the ABS system or specially fitted sensors. When wheel spin is detected the engine power is reduced, by cutting a single injector pulse or a spark, until grip is resumed. This occurs in a thousandth of a second, and appears to the driver as a slight miss-fire with no loss in acceleration. Utilization of this type of system gives the owner access to cutting edge technology designed specifically for the sole purpose of taking advantage of the extreme power derived from such an exceptional build.
We would like to thank Mike (bullitt5897) for allowing GTM Performance Engineering the opportunity to pioneer the first four digit build on the Nissan 370Z and VQ37VHR platform. Due to the bleeding edge aspect, this uncharted journey is bound to be fraught with many challenges and perils. We realize this and appreciate Mike’s trust in our capabilities, knowledge, research, development and engineering. Sit back, relax and enjoy as this build unfolds into epic proportions.
Featured components:
- GTM Stage 6 Twin Turbo kit with dual GT35R turbos
- GTM 4.5L stroker mid- sleeved block
- GTM Billet stroker crank with 96mm stroke
- GTM Arias extreme HD pistons
- GTM GTR intake manifold conversion
- GTM 3" True Dual Exhaust
- L19 Head Studs
- Cometic Head Gaskets
- GTM Stage 1 Heads
- GTM springs and Titanium retainers
- GTM Stage 5 Return Fuel System
- Denso 1000cc primary and secondary injectors
- OS Giken Triple Disk Ceramic HR Clutch and Flywheel
- HKS F-Con V Pro
- HKS Knock Amplifier
- HKS EVC 6 Boost Controller
- Racelogic Traction Control system
Pics of Featured components:
Pics of the car upon arrival and base line dyno
Sam@GTM is offline
Old 06-19-2010, 10:08 PM
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
We will be documenting a lot of the progress via video as well. from the tear down process, engine assembly, engine install and tuning . Will start with a little blast from the past and a taste of the present
<object width="660" height="525"><param name="movie" value="http://www.youtube.com/v/vDO9Ho1kKhs&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b&bo rder=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/vDO9Ho1kKhs&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b&bo rder=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>
<object width="660" height="405"><param name="movie" value="http://www.youtube.com/v/fVz7DzpR0Ww&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b&bo rder=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/fVz7DzpR0Ww&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b&bo rder=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="405"></embed></object>
Sam@GTM is offline
Old 06-19-2010, 10:10 PM
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Reserved for engine removal and tear down
Sam@GTM is offline
Old 06-19-2010, 10:12 PM
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Reserved for engine machining and assembly
Sam@GTM is offline
Old 06-19-2010, 10:13 PM
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Reserved for the install process
Sam@GTM is offline
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Reserved for tuning and testing
Sam@GTM is offline
Old 06-19-2010, 11:44 PM
Litesung
Litesung's Avatar
Definitely worth subscribing. When do you guys expect to finish?
Litesung is offline
Old 06-19-2010, 11:54 PM
adamciya350
adamciya350's Avatar
sub'd
adamciya350 is offline
Old 06-20-2010, 12:22 AM
hellsoldiers08
hellsoldiers08's Avatar
Will that rim come in a 19 for 350z offset specifications?
Also, if it not to much trouble could you shoot me a pm on pictures of the car? Im trying to put it on my background on my computer. Love the way this 370z looks. cant will for you guys to hit the 1000hp mark, Good luck
hellsoldiers08 is offline
Old 06-20-2010, 03:39 AM
jumpin800agl
8 to 11
jumpin800agl's Avatar
awesome news!
jumpin800agl is offline
Old 06-20-2010, 06:52 AM
diablox1
diablox1's Avatar
this is sick. in for moar pics.
diablox1 is offline
Old 06-20-2010, 07:37 AM
ZeeForce
ZeeForce's Avatar
Subscribing
ZeeForce is offline
Old 06-20-2010, 10:08 AM
supernadc2
supernadc2's Avatar
GTM - You continue to out do yourselves. Looking forward to seeing this being done. lol im kind of scared now to send my car there as i know where a lot of time will be dedicated lol. Jk. This is definitely a great project, good luck with the build, subscribed!
Mike from Georgia, your very fortunate .. actually to even be able to say your attempting this is amazing. Congrats.
supernadc2 is offline
Old 06-20-2010, 04:36 PM
SQBassHead
SQBassHead's Avatar
SQBassHead is offline
Old 06-20-2010, 09:14 PM
APOCOLYPSE DAWN
APOCOLYPSE DAWN's Avatar
Thanks for the compliments guys! GTM is GREAT and SAM has gone way out of his way to help make my dream possible! I hope yall enjoy this build as we have a lot of kool pieces of this build to show you all. We have some big JDM manufacturers that may join in on the fun as well. I will keep that under wraps until its finalized
Hellsoldier08: Yes that wheel comes in 19's and in offsets available to you guys from Rick at VIP STATUS. Those wheels are no longer on the car and I am waiting for Strasse Forged to finish the new 20's that will be going on!!! They are going to be SICK!!!
Mike
APOCOLYPSE DAWN is offline
Old 06-21-2010, 06:13 AM
Hexxus
Hexxus's Avatar
What is this GTR intake manifold conversion being spoken of? Would it also work for the VQ35HR?
Hexxus is offline
Old 06-21-2010, 06:38 AM
APOCOLYPSE DAWN
Yes their will be one available for the VQ35HR you guys are in luck! this is the first production unit being installed and tested.
Old 06-21-2010, 08:08 PM
GBoger
GBoger's Avatar
sub'd for the completion sometime next year
GBoger is offline
Old 06-22-2010, 09:15 AM
APOCOLYPSE DAWN
hahahaha gonna be much sooner than that Gboger
Old 06-22-2010, 09:54 AM
str8dum1
str8dum1's Avatar
Should be fun. Would love to hear a realistic time frame for this. 6 months at least is my guess.
str8dum1 is offline
Quick Reply: GTM Performance Engineering VQ45VHR-Our Journey to The 1000 HP and Beyond
