MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Forced Induction (https://my350z.com/forum/forced-induction-182/)
-   -   Suggestions from experienced FI'ers (https://my350z.com/forum/forced-induction/551327-suggestions-from-experienced-fiers.html)
gixx76 Mar 21, 2012 06:40 AM
So I have been on the fence for long enough now and have decided to start small and see where it goes. Only issue is I am having trouble deciding on the Best TT kit for what I am looking for.
Looking for 350-400hp minimum to start.
Kits in mind...
Greddy tt kit(non tuner)
JWT TT kit
I am in Canada and there is not much as far as tuner action in the city I am in so I was hoping to get some insight. I currently have Stock motor (DE) with EVO2 trul dual exhast.
Other parts I am looking at..
• Profec E01 Boost Controller
• 1 Step Colder Copper Spark Plugs
• WB Sensor
• (2) E01 External Hanesses
• E-Manage Pressure Sensor Harness
• Crawford Plenum
• Crawford Strut Bar
• Walbro 255
• Aeromotive 1:1 FPR
• Fuel Return Lines
• Turbonetics Waste Gate Gaskets
• JWT Clutch
• JWT Flywheel
• JWT Oil Pan Spacer
• E-Manage Timing Harness and rectifier diodes
• Greddy Type S BOV
These are items I saw that another member suggested but would like feedback on what is nesc. and what is not required or really needed.
Thanks In advance guys.
konrad Mar 21, 2012 07:55 AM
Why not single turbo ?? Boosted performance is in Canada and he makes a very good single turbo kit. His work is superb. If you get the 6265 turbo kit you will spool a little slower than a twin turbo kit and make good power. Also it will be much cheaper to buy it and install it since you don't have to pull out the engine.
As far as the extra parts, I would go with utec over the e-manage , you can find one cheap in the marketplace, you can get the utec boost controller $100.
You won't need no wastegate gaskets or type s BOV if you go with the BP kit.
Also for 350-400 whp you don't need a fuel return or FPR,
bmccann101 Mar 21, 2012 08:10 AM
agreed, id stay away from utec as its discontinued and transitioning btween its cycles is rough for some ppl..its kind of a WOT, on or off system.. go Osiris.
BP is a great way to start, and he is a very active forum member and will happily talk to you about what you need if you PM him or look for HIS thread.
do that, and read all the FI stickies please.
Boosted Performance Mar 21, 2012 08:17 AM
The people have spoken...:thumbup:
Reality350 Mar 21, 2012 08:18 AM
^Msg this guy.. :thumbup:
konrad Mar 21, 2012 10:46 AM
there were only a few cases with the utec closed to open loop problem, most people don't have a problem, i had a utec with 760cc injectors with no problems .
Osiris will end up coating more with the boost controler over a utec with txs boost selonoid
gixx76 Mar 21, 2012 10:51 AM
Thanks for the responses guys..pm sent to BP.
Alberto Mar 21, 2012 11:21 AM
You lost me at Emanage
suprasam Mar 21, 2012 12:20 PM
I would recommend now worrying about the crawford plenum either. For your current goals just put that money else where.
gixx76 Mar 21, 2012 04:04 PM
Where would you suggest?
Basically im looking for all the different options that people are using or have used and gotten the best results from that set up, I have read the stickies on FI for newbs but it doesnt give you real peoples actually success with the different set ups...great info but I am looking for info on actual set ups on stock motors that have satisfied the 350-400hp mark with reliability:))
IslandZavage Mar 21, 2012 04:26 PM
Buy a plenum spacer. Same result and less money than the Crawford...
konrad Mar 21, 2012 08:30 PM
with a BP single you will make 400 whp easy @ 8psi
djamps Mar 22, 2012 07:15 AM
I have before and after dyno sheets with a spacer... no gains at all in F/I. Pressurized air flows much differently than in a vacuum.
konrad Mar 22, 2012 07:27 AM
If you are looking for a Crawford plenum I have one that I won't be using , I can send you picks.
Resmarted Mar 23, 2012 12:16 AM
Air doesn't flow in a vacuum :icon8:
djamps Mar 23, 2012 02:47 AM
Do you want a cookie smarty pants? LOL
Sylvan Lake V35 Mar 23, 2012 07:18 AM
What city do you live in OP?
Resmarted Mar 23, 2012 12:22 PM
:icon38: yes... I have milk...
I'm not quite experienced yet with my z actually being boosted, but if I could do it all over again, I'd either stay stock block with twins or supercharger and call it a day, OR have gone straight to dynosty to build my block... no fuxing around with local people. OR I would have gone 2j. Not a huge fan of v-8's... Don't get me wrong, they are awesome for power and all that, just not my style...
Sylvan Lake V35 Mar 24, 2012 07:59 AM
If i did it again it would have been an RB 26 or RB30 or I might have tried something really cool and did a nissan TB48.
I still think the RBs are smaller displacement and old technology but the money have spent on my set up :o at least with the RB I would have something different making a "reliable" 550whp :thumbup:
Robert_K Mar 24, 2012 08:44 AM
I still think the RBs are smaller displacement and old technology but the money have spent on my set up :o at least with the RB I would have something different making a reliable 550whp :thumbup:
I think if I was to do it all over I have three options;
1) Build a high-compression N/A VQ track-prepped screamer.
2) Build a high-compression N/A LS track-prepped screamer.
3) Paid it off sooner and bought a GT-R. :suicide:
