return fuel system with surge tank
I'm about to set up a swirl tank on my car and the simple thing would be for me to run a 255 to feed the tank, and an external 255 from the tank to my motor. Will the OEM pressure regulator flip out from the added pressure or will it do it's job just fine? Has anyone run one in a basic NA config without extra needed parts or extra tuning.
I'm tired of fuel starve under 1/2 tank , not to mention my car will be a lot lighter if I don't have to go out on track with close to a full load. The pot will sit under the factory enclosure, the glove box hole and sub hole are getting covered in sheet metal to seperate them from the interiour . |
So basically, can I run a 255 fuel pump on an NA setup without additional problems or tuning?
Once I get the swirl tank setup , I will post a full how too. Can't wait for fuel starve to be gone. |
you have a return fuel system right?
you will need to have at a minimum a return overflow from the surge tank back to the stock tank (which necessitates a return fuel system). To run a surge tank properly, you need a return fuel system and an external FPR. The return fuel dumps back into the surge tank. and the overflow back to the stock gas tank. |
Originally Posted by str8dum1
(Post 9771128)
it wont see extra fuel pressure... nothing will change.
You're starving at less than 1/2 tank regularly or intermittently? |
ninja edit-- above. he needs to have an overflow back to the stock tank.... the 1st pump runs at basically 0psi and will pressurize the surge tank in no time without a return overflow.
(Post 9771128)
you will need to have at a minimum a return overflow from the surge tank back to the stock tank (which necessitates a return fuel system). To run a surge tank properly, you need a return fuel system and an external FPR. The return fuel dumps back into the surge tank. and the overflow back to the stock gas tank. In tank pump to surge tank Surge tank to external pump, plumbed back to the OEM fuel line going to engine Return/dump off top of surge tank run back into the OEM fuel tank, most likely above the pickup like you would on a return fuel system loop from the engine. I starve on longer right handers below 1/2 tank, and it has gotten worse with the latest aero. |
In for updates
http://shop.cj-motorsports.com/CJM-F...fpofitting.htm is what I'm grabbing to hook up the OEM fuel line to the surge tank, the 255 internal and external pumps are easy to find , surge tank I just need to measure and get one that fits , only thing in the air is a fitting to hook -6 line back into the OEM fuel system.
a overflow back to the stock tank needs the return parts in the stock basket.
You basically just repeated what I told you.
(Post 9771153)
No need for a return system
(Post 9771576)
You basically just repeated what I told you. Being NA I get around 8 mpg on the track, if could pull enough G's to make the surge tank starve at half full (it won't be as easy as the OEM fuel tank because it's not a saddle setup) I would have to keep a constant rt hand loading for 2 miles, thus keeping the in tank pump from feeding the surge extra gas. I think this will work for any track junky That is not running a return system, probably easily modded to a return FI style system too. Full interiour cars will need to relocate to sub and glove box, sub to the pass side, glove box to drivers side. Very simple and easy to do. |
(Post 9771714)
Edits and stuff, I probably already clicked reply . No big deal, but the part where I said no return sytem is needed, I mean the main fuel system to the engine and changing the regulator. Since I'm keeping the OEM non return system it will take a lot longer for the surge tank to empty and starve when the in tank pump starves.
Being NA I get around 8 mpg on the track, if could pull enough G's to make the surge tank starve at half full (it won't be as easy as the OEM fuel tank because it's not a saddle setup) I would have to keep a constant rt hand loading for 2 miles, thus keeping the in tank pump from feeding the surge extra gas. I think this will work for any track junky That is not running a return system, probably easily modded to a return FI style system too. Full interiour cars will need to relocate to sub and glove box, sub to the pass side, glove box to drivers side. Very simple and easy to do. Just let us know what you find out, new to this fuel starvation problem, but rather be safe than sorry. Have to do some more reading on the subject |
So, did you end up getting a swirl tank and pumps?
sub'd
(Post 9827019)
how crap how have i missed this one?
my setup, obviously NA dosnt need dual 044's for external pumps though. http://i34.photobucket.com/albums/d1...-06-13_545.jpg only difference is the pumps are flipped around now to accommodate the lines in the car. running a setup like this no issues even with a return setup since the fuel swirl pot has to be completely full to push fluid out the top back into the tank(the tiny -4 an), the -6an is the return from the fpr, the -8an on top is the feed and then dual -8an to the pumps but again not needed for NA one is enough. not sure on the baffling inside would have to ask sasha on the details for that. a note though the stock pump in tank should be more then enough with a 255 feeding up front. you will get slightly more flow then the 255 can provide on its own. |
So Jerry , your saying to just leave the OEM pump in place and run a 255 from the swirl tank to the motor?
for NA? i would no need for something more, since the intank isnt providing any pressure its quite possible it will produce more volume then your 255 external. now if you have a 255 intank already then go for it just w/e is cheaper either one will work. the 255 should be able to get just a little bit extra fuel since they dont have to "suck up" fuel so they can provide a little extra flow at the same pressure compared to normal.
The 255 external is ordered from www.nissanraceshop.com , the adapter from the OEM fuel pump to -6 fittings will be ordered from CJM tonight, finally starting to get this project going.
Nice. Post pics if you can.
Still in work, got the fittings together now, pump, tank , now I just need an external fuel pressure regulator.
