Haltech Pro Plug-in..NEED help from GURU's
1 Attachment(s)
I posted this on Hal's thread but no repose hopefully i get one quicker so i can start my TUNE alrdy.. so basically this is the problem im having..
The connector that plugs into the Haltec for MAP, IAT, boost control and the wide bands is pretty much busted. The wires that are in there are wired incorrectly, and there aren't enough wires for what we need to do.Also, If you notice that you can "see into" the connector... It isbecause it is broken and missing its locking tab. basically where can i buy one.. Ive looked all over n cant.. Also if there is any solution plz help.. OR even better if anyone has a used one or new one for sale i would need it asap.. Car has been sitting for almost 3 weeks.. This was the last step i needed done n now stuck.. Mostly my fault for buying used one.. |
Try anyone that sells Haltech.
PM Sent.
We offer two solutions: 1. Plugs & Pins (unpopulated, requires crimp and wiring to your desire) 2. Auxiliary Harness (populated with wires, just connect as you wish) Call or email to order. |
SOLVED!!!
Just ordered new Auxiliary Harness from Dynosty |
| All times are GMT -8. The time now is 05:54 PM. |
