Final Drive FI gearing: What's yours?
Looked around for a thread on this and didn't find a collection thread listing what final drive gearing FI cars are running and the results. It would be nice to have everyone's info in one thread for quick/easy future reference of others.
If there is another thread like this, please point me to it....but I spent 20 minutes with the 'search' button and didn't find what I was looking for. I think it would be helpful to have the following info in each reply, I'll start..... FI type: Vortech V2 SCI-trim engine displacement: 3.5L rwhp: 385 6mt or 5at: 6mt rear tire size: 275/35/19 LSD type/brand/settings: OEM VLSD half shafts: OEM ring/pinion gearing ratio: 4.083 typical use: street & occasional track day (road race) likes/dislikes regarding gearing: can't build boost in 1st gear before hitting rev limiter. Can only build 3psi in 2nd gear before hitting rev limiter. Can't hook up in 1st on hard core launches even though both wheels are pulling for the most part plans to change final drive: Yes! Have 3.53 gears with Nismo diff set to 1.5way @ 60% lock. Installing it next week. --Sk |
as fast as the rpms move in first gear the pressure in the charge pipes and the intercooler doesn't have time to build up and pressurize the manifold.
652hp single turbo: 3.54 rear end (stock g35 6mt) |
FI type: Vortech V2 SC-trim
engine displacement: 3.5L Stock rwhp: 513 rwqt: 408 6mt or 5at: 6mt rear tire size: 285/35/19 LSD type/brand/settings: OEM (Euro Spec) VLSD very few in the US half shafts: OEM ring/pinion gearing ratio: Stock 3.535 typical use: street & occasional Drag Racing likes/dislikes regarding gearing: 1st gear is a little low |
nice thread, in for more results. I was thinking about changing the gearing when I do a lsd upgrade.
Me too. I think I am going to wait till my car is running, and then make the choice on wheather or not I like the OEM VLSD... But also in for more results and feedback.
FI type: Vortech V3
engine displacement: 3.5L rwhp: 458 6mt or 5at: 6mt rear tire size: 275/40/18 LSD type/brand/settings: Quaife half shafts: OEM ring/pinion gearing ratio: 3.90 typical use: street (non-dd) and track (road course) likes/dislikes regarding gearing: 1st gear is kinda useless? :o |
Stock for F/I. 4.083 is better for N/A.
Originally Posted by djamps
(Post 9935887)
Originally Posted by Escobar
(Post 9937298)
can you elaborate. Wouldnt 4.083 be beter for FI since RPM would rise quicker or do I have it backward?
FI type: APS TT
engine displacement: 3.5L 9:1 cr rwhp: ~550 hp ~575 tq 6mt or 5at: 6mt rear tire size: 295/35/18 LSD type/brand/settings: oem VSLD half shafts: OEM ring/pinion gearing ratio: 3.3 from an auto typical use: street car likes/dislikes regarding gearing: with the 3.53 stock, the car was useless in 1st and second. with the move to 3.3, the car is much more drivable, and I can actually use 1st gear. I wouldn't move to the 3.3 with less than 475-500. it gives you a lot of gear. and for some, 4th and 5th might seem sluggish |
Originally Posted by jamestown
(Post 9937328)
No, because of traction problems.
Originally Posted by Zivman
(Post 9937469)
4.0 for N/A 3.5 for stock block F.I 3.3 or less for big boost |
(Post 9937603)
^^ This.
i believe moving to 3.3 you must be above 650rwhp.
if you are having traction problems check your tires and suspension set-up. make sure you are not seeing any negative camber on your wheels. a good set of r888 will be very good. |
I know this is an old thread, but I don't want to get flamed for starting a new one. I noticed the other day that Nissan does have a 3.7 FD gear. Would that be too aggressive or just right for a single turbo DE at ~400whp, ~390wtq?
IMHO too agressive
it's a waste of time and money.
stock 3.54's will work better for you.
Originally Posted by Wilhelm
(Post 10348954)
Some good info in here. Sub'D..Thanks guys
(Post 10348954)
3.9 FD @ 350-400whp is stupid fun. It makes the Z feel like a monster in any gear for a fraction the cost of building a high hp Z.
I'm on the fence for the 3.3 swap, if you want 200+ mph 3.3 seems like the way to go. I wouldn't make the gearing a function of power as much as use of the car. |
| All times are GMT -8. The time now is 06:45 AM. |
