has anyone seen a VR block with 370 heads yet?
heard this is possible and zfever was working on one but havent seen any info on it, vr38 block with 370z heads into a 350z
Sounds like too much work....Stick to your LS swap hahah...Hows that monster clutch holding up?
Jeremiah |
Originally Posted by Total D
(Post 9978739)
Jeremiah |
why bother changing the heads?
Originally Posted by str8dum1
(Post 9978781)
I've read that z fever made g37 heads fit on the vr38 block. But then the issue of what transmission will you use comes up.
Originally Posted by ace32x
(Post 9978790)
from what i was told the gtr heads wont work in the swap.
Originally Posted by RudeG_v2.0
(Post 9979132)
I don't understand why. Even if there was an issue with the VQ ECU controlling the VR motor, couldn't they swap the ECU too or run a full stand alone EMS?:dunno:
Originally Posted by graffkid732
(Post 9979215)
My thought exactly. Maybe I am missing something.
Its easier and cheaper to fine full stand alone for the HR and VHR heads than the VR heads.
For me, I would rather use the HR heads. Over 300cfm stock FTW |
Originally Posted by midz350
(Post 9979491)
Originally Posted by djamps
(Post 9979573)
From what I understand there are no standalones that can control VR/VHR heads properly (due to VVEL). I'm guessing Zfever swapped to HR heads because of this.
(Post 9979659)
OK, but again that begs the question of why don't they swap in a VR ECU as well.:dunno:
(Post 9979659)
A more plausible route might be VHR heads and a VHR ECU. Or HR heads and a stock ECU (as the customer chose). Hell it could be financial reasons on behalf of the customer, I doubt a VR swap is cheap all by itself. |
(Post 9979767)
Getting a GTR ECU to play nice with the Z BCM and OEM cluster...that's a ton of work if it's even possible. Two totally different cars.
it is not different than putting the original haltech (stock ecu + piggyback) in a VQ35de or swapping in the LS1 (piggyback stock ecu with gm ecu)
the GTR ecu only needs to control engine functions. The tach might not work, but its no different than an LS swap. Better yet, run the GTR motor on a Proefi or Syvecs and dont even worry about the gtr ecu. So i still dont know why they'd mess with running 370z heads when the full GTR package is way superior.
(Post 9979767)
But the question is would it be worth the added cost? How much better to VR heads flow than HR heads? Would the stock rods give out before the heads started limited flow?
Wiring in the GTR ECU especially if it's never been done before would add significant cost to the build. The customer's wallet ultimately decides what happens. |
(Post 9980346)
(Post 9980401)
i dont think the hr heads work on them, theres a little difference between the hr and the vhr heads height wise
(Post 9980577)
if it's vhr heads going onto the vr block I'd be even less worried about flow issues and more welcome to the simplicity of not hacking in a gtr ecu.
